2.1 Surround Sound vs 5.1 or 7.1
When deciding on the type of speaker to use in your car, you are likely to find that 2.1 surround sound is one of the options. Comparing them with other speaker set ups will enable you to determine which one will be best for your purposes.
Purpose
5.1 and 7.1 surround sound speaker systems are designed to enhance the television watching experience by improving the way you hear the audio. 2.1 surround sound will provide the basic audio necessary to enjoy visual and audio entertainment. The former varieties of surround sound speakers will be suited to a large home entertainment system, while this may not be strictly necessary for a car stereo. The quality of the sound is improved with the use of surround sound speakers and can help to remove interference.
Use
The next step necessary to determine whether 2.1 surround sound will be useful for your car is to consider what the speakers will be used for. If you have a stereo in your car that is only used for basic audio, you are likely to find that the basic 2.1 level of speaker are sufficient. However, if you have the type of car that comprises miniature television screens on which DVDs can be watched, more extensive speakers may be beneficial. Using 5.1 and 7.1 surround sound speakers with a home theater system will help you to create an atmosphere that resembles the atmosphere of a movie theater.
Installation
2.1 surround sound speakers work with the use of just two speakers, making it the easier option when it comes to the installation process. The process for installing them is also likely to be easier, as they will take up less space, whether this is in the home or the car. The positioning of the speakers for 5.1 and 7.1 surround sound speakers is important to get right in order to get any benefit from them.
Power
Check the manner in which the speakers are powered and whether this will affect the energy expended. You are likely to find that the higher levels of surround sound speakers require more power.
The power that is required for 2.1 surround sound speakers will be less than that for its higher level counterparts. In addition, there are a larger number of speakers required for the 5.1 and 7.1 variety of the surround sound systems
Compatibility
Not every type of equipment will work with all types of surround sound speaker systems. Using 2.1 surround sound speakers may be the only option for basic types of stereo or entertainment system, as 5.1 and 7.1 will not provide any additional benefit. Prior to purchasing new speakers, check the details of the system to determine which type are recommended. If you opt for the latest technology but fail to do the same for the speakers, the purchase will be a wasted one. Ensuring that the speakers are suitable for the equipment they are to be coupled with will ensure that quality sound is produced.
