3 Advantages to Using a Water Heater Blanket
If you use a water heater that is not equipped with a water heater blanket, you should seriously consider having one installed. Water heater blankets are quite simple, and can easily be made by a person with no special skills or equipment. However, do not be fooled by the simple nature of water heater blanket. They can save you a great deal of money on your gas bills, as well as reducing your energy consumption. Water heater blankets can even save you a lot of time and effort. The following should explain to you the many significant advantages to having a water heater blanket installed on your water heater tank.
Cost
While a water heater blanket costs money to acquire, whether you purchase the materials and make it yourself or simply buy a pre-made water heater blanket, and additionally costs time to install, putting a water heater blanket on your water heater is still a money saving move in the long run. This is because water heater tanks often do not retain heat as well as they should. If your water heater tank is radiating heat from itself, that means that energy that should be used to heat your water is simply being wasted. This means that energy you pay for is not doing its job.
If you install a water heater blanket on your water heater tank, this will change. Your water heater blanket will use its powerful insulating properties to keep the energy you pay for on the inside of your water heater tank. This will reduce the amount of energy your water heater uses, which will lower the amount of energy your home uses, which will lower your energy bills. Whether you have a gas powered water heater, an electric water heater, or a water heater that uses another power source, this is a smart move.
Energy Use
Your water heater blanket, in addition to saving you money on your energy bills, will also reduce the amount of energy that your home uses. If you are interested in doing your part to help protect the environment, this can be a big bonus, especially when you consider the tiny startup cost of installing a water heater blanket. For only a few dollars and a little bit of work, you can dramatically reduce the amount of fossil fuels your home consumes—whether they are burned to produce heat directly or burned to produce electricity that provides you with hot water.
In contrast, if you do not use a water heater blanket, you will consume energy that is only use to inefficiently heat the outside of your water heater tank.
Convenience
A water heater blanket can also potentially keep your water heater running more efficiently. If your water heater is using less energy to successfully heat the water in its tank, this means that the water will retain heat better and heat up more quickly. If this happens, you will find yourself running out of hot water much more infrequently, saving yourself a great deal of trouble when you take a shower, wash dishes, or do other common tasks that require hot water.
Find Trusted Professionals For Your Plumbing
