3 Basic Radiator Maintenance Tips
Proper radiator maintenance is vital if you want to keep your vehicle in good running condition. The following tips will help you ensure that the radiator in your car or truck's cooling system works properly. Keeping your radiator properly maintained can help to eliminate expensive repairs later.
Tip # 1 - Check Your Fluids
Fluids are the lifeblood of your radiator. You should check your coolant levels to ensure that you have the proper amount of fluid in the radiator. This will help to keep the car from overheating in hot weather and keeps the water from freezing in colder climates.
Tip # 2 - Flush the Radiator
Flush the radiator every 1 to 2 years regardless of how many miles you have put on your vehicle. This will remove buildups of rust and sediment that can cause problems with your radiator.
Tip # 3 - Maintain the Hoses and Belts
Check the radiator hoses and belts. Look for leaks or cracks in the hose and look for cracks in the belt. Do this each time you change your oil and you will be able to catch problems with your radiator early.
Simple and regular radiator maintenance as shown in the above tips will be able to prolong the life of your vehicle and ease the burden on your wallet.
