3 Benefits of Cold Carpet Seam Tape
Cold carpet seam tape has been used by professionals for a long time. Here are a few of its many benefits.
1 - Aggressive Adhesive
Cold carpet seam tape is not just stable, it also offers an extremely aggressive adhesive for every project. When you fix your carpet or join it with this tape, it is sure to be permanent. Because of this, you will save money in the long run, not having to get it fixed.
2 - Mildew Protection
Not only does this seam tape hold really well but it also protects against any mildew and water penetration. Often times people will spill on their carpets and water or liquid will soak through the seams and gather under the carpet. Later on it will end up smelling and molding. The cold seam carpet tape keeps this from happening.
3 - No Ironing Needed
When you are using steam tape you have to use the iron to activate it which ends up becoming a mess at times. When you install the cold seam tape you can just put it in there without any special tools needed or even ironing and it is just as good if not better than the heated carpet seam tape.
