3 Best Ways to Secure Items in a Shadow Box
A shadow box is actually a type of picture frame, but unlike a normal picture frame, it is much deeper and allows various objects to fit inside. Popular items to fit inside shadow boxes include wedding invitations, baby clothes, tickets, and various other mementos; however, you will need to secure whatever it is you are putting in the frame somehow. There are actually three different techniques that can be used to fix your things in place.
Choosing the Right Way to Secure Items
When securing items inside your shadow box, it's important that you choose the right options for each part of your object. You will want the shadow box to last for as long as possible, without items inside moving, which is why choosing the right method of fixing items is so important. Take into consideration both the weight and the material of all of your pieces when deciding how to proceed.
1. Double-sided tape
One of the easiest methods of securing items inside a shadow box is using double-sided tape. This makes it very simple to position the items and also means that you can easily move them if you need to. The only problem with double-sided tape is that it's not really suitable for very large or heavy items. Over time, the double-sided tape will lose strength and come unstuck, which will allow heavier mementos to fall.
Using double-sided sticky tape is perhaps the simplest method, and it's also the least messy option.
2. Pins
Another option is using a pin to push through the item and stick it to the backboard of your shadow box. However, this is only suitable for certain types of objects, such as toys, children’s clothing, or paper. The only real disadvantage to this strategy is that the pinheads will be visible for all to see. This can be turned into a positive result if you use stylized pins or certain colored pins to create an organized look.
3. Hot Glue
Using a glue gun is another way to secure all kinds of items inside a shadow box. It creates a very strong bond that should not come loose over time. However, hot glue guns are not suitable for gluing everything. Anything porous may absorb the glue, which will, in turn, prevent it from holding properly.
Whichever technique you decide to use to fix your shadow box items in place, you need to ensure that they are held firmly where they are. Ideally, this box will stay on the wall for a long time, and you really don't want things to drop off and ruin your display.
