3 Common Causes of a Clogged Kitchen Sink
Having a clogged kitchen sink can be a very annoying thing to experience. Understanding that there are several reasons your sink can get clogged can be both frustrating and time-consuming. Instead of going back over all the activities you did in the sink to determine the cause of the blockage, read on for enlightenment.
1. Food in the Drain
One of the most common causes for a clogged kitchen sink is food getting stuck in the drain. Before cleaning dishes, food that is left on dishes can slip into the drain and stick to its walls, clogging it. The most common food items that are effective in sticking are cereals and soft bread particles.
2. Grease
When the grease from your food is in liquid form, it can run down a drain effectively. The problem arises though when the grease solidifies. It tends to solidify when it cools down and then easily sticks to the walls of the drain. The grease may not directly clog the kitchen sink but even the most random particles falling in the drain now will stick to the grease and aid clogging.
3. Foreign Objects
If you have kids around your house, foreign objects falling into the kitchen sink can be a common cause for clogging. Kids tend to throw objects like jewelry and small toys into the drain for fun. The drain can simply easily get clogged when that happens.
