3 DIY Tips For Cleaning a Fuel Injector
If your fuel injector is in need of a good cleaning, you may be wondering how to go about administering it. If so, you're in luck, because this article will supply you with a number of helpful tips for making that dirty fuel injector nice and spotless.
Acquire a Good Cleaning Kit
If you intend to perform a fuel injector cleaning on your own, it is of paramount importance that you purchase a high quality cleaning kit. These kits, which are designed specifically for cleaning fuel injectors, are a little pricey, but generally pay for themselves after two or three cleanings.
Have a Guide to Car Engines on Hand
As this is a job that will require you to open up your vehicle's engine compartment, it is recommended that you keep a detailed guide to car engines on hand, particularly if you are unfamiliar with the inner workings of cars.
Make Sure the Fuel Injector is Prepped for Cleaning
Once you've opened up your car's engine compartment and successfully located your fuel injector, you'll need to ensure that fuel is not being pumped into your engine during the cleaning. To do this, either use tubing to connect your engine's fuel inlet to its fuel outlet or simply remove your fuel pump fuse, and/or relay, and stop up the engine's fuel return.
