3 Easy Ways to Clean a Paint Brush
If you do a lot of painting, you may be curious about the easiest methods of paint brush cleaning. If so, you'll be pleased to know that there are number of easy and effective ways to make your dirty paint brushes as good as new. Read on to learn the basics of paint brush cleaning.
Step 1 - Wipe the Brush with a Rag
If there is a large amount of excess paint on your brush or brush handle, use an expendable rag or washcloth to carefully wipe it away. This method only works if the paint is still wet, so be sure to tend to copious amounts of excess paint forthwith.
Step 2 - Rinse with Turpentine
Rinsing your paint brush with turpentine is a great way to clean it if you frequently use water-based paints. Follow this method up with a thorough rag wiping.
Step 3 - Rinse with Warm Water
A traditional water rinsing is another good way to clean your paint brush. When using this method, make sure the water is of a lukewarm temperature. Keep in mind that hot water stands to damage your brush's bristles. If you encounter any stubborn patches of caked-on paint, you may want to incorporate the aid of a mild soap - but never a commercial detergent or dishwashing liquid.
