The 3 Most Popular Options to Finish a Basement Floor
concrete basement floor
You can finish a basement floor in a variety of ways. A basement floor that has finishing is better protected against water and moisture damage. There are three major options to finish your basement floor. They are sheet vinyl, concrete, and engineered wood. Although there are other options, such as wood finish, these three are widely used for their cost-efficiency, fire resistance, moisture resistance, and aesthetic value.
You can easily install any of these three options to finish a basement floor without hiring a professional carpenter. As in all home improvement projects, always wear protective gear when installing your own basement floor finish.
Sheet Vinyl
Sheet vinyl is a famous finishing option used in basement floors all over the world. It comes in various patterns and colors, which makes it ideal for those who want broad design options for their basement floors. Vinyl sheet is perfect for basement floors which are uneven or sloped.
Sheet vinyl is the easiest to maintain and clean among the various basement floor finishes. It can withstand floods very well, especially if seam tapes are added along the floor joints. Seam tape, when applied with heat, seals your basement floor and prevents water and moisture damage to your basement floor.
Concrete
Concrete finish is ideal for basements that are used as storage area or a workshop. It is the simplest and most affordable finish. When installing a concrete finish to your basement floor, all you have to do is purchase concrete seal at your local hardware shop or home improvement store.
Apply the concrete seal on your basement floor with a paint roller. The concrete seal prevents moisture from seeping through your basement floor. There are also many design options from which to choose for your concrete finish. For example, you can stencil your concrete basement floor or use dyed concrete seal.
Engineered Wood
Engineered wood is an excellent basement floor finish because it is more resistant to temperature changes and moisture when compared to other floor finishes. It is made of thin layers of bonded wood on resin backing, which looks like a real hardwood. Engineered wood is an ideal basement floor finish in areas with extreme varying temperatures and low moisture.
Engineered wood is much less expensive than real hardwood. It is not directly attached to your basement floor. Instead, it floats inches away from the basement floor, making it an ideal floor finish for basement floors that are uneven, warped, or sloped. It is the preferred basement floor finish for most do-it-yourselfers, since engineered wood is relatively easy to install. Unlike laminate basement floor finish, you can refinish and sand engineered wood.
