Plumbing
Featured Articles
Learn how to read your system.
Set up your system to work for years to come.
Find the best solutions for keeping things dry.
A lush lawn means something different to septic tank owners.
Plumbers hate it.
Find the source of the mystery sound.
Keep water flowing when needed and stopped when not.
They're both safe, but they affect plumbing differently.
It's important to check your septic every few years and to do that, you must find and locate the lid.
Get it up to code.
Problems with water meter readings and function can stem from a variety of sources.
This powerful substance requires special handling.
Your drinking water is not as safe as you think.
PEX piping has several qualities that give it an edge over other materials.
If you have some experience in plumbing, you might add a backflow preventer to your pipes.
A drain snake can save you a pricy plumber's visit.
Calcium buildup in piping can be inconvenient and troublesome, but it doesn't have to break the bank.
That hidden water sound can drive you bonkers.
This common problem has a few potential causes.
Fix plumbing problems before they start.
Make them longer!
Replacing your water heater expansion tank by yourself can save you a lot of money and time.
Slow and steady cuts aluminum..
It's not as impossible as it sounds.
