3 Tips for Using a Pressure Washer Detergent Injector
Whenever you are working with a pressure washer detergent injector, there are some things that you should keep in mind. You will find that the more that you understand about the tips and hints that you should know about when using this injector, the easier the job will be. Improperly using the power washer when using the detergent injector can cause damage to not only the area you are washing, but to the pressure washer itself. Make sure that you make the right decision and educate yourself on the necessary things to keep in mind so that you will be able to get the job done easily and safely.
Pressure
The most important thing that you will need to keep in mind is the amount of pressure that you are using whenever you are spraying chemical cleaner with your pressure washer. Whenever you are in a rush, you will of course want to spray with the highest pressure possible. However, this is something that is not going to get the job done any quicker for you. The detergent will need to be applied on a low pressure. The first reason for this is that the force and the speed that it would hit the surface will only make the solution splash off. This will of course make the job go much slower and end up being a big waste of your time and money as you will end up needing to use more detergent. Whenever you are working with a chemical injector, you will find that the wand will allow you to have the ability to switch from low to high pressure. This will be necessary whenever you are switching from applying the detergent to spraying it off.
Safety
It is very important that you practice safety whenever you are working with your pressure washer. Whenever you are applying detergent, you will need to make sure that you are wearing gloves as well as protective clothing. It is also a good idea to wear goggles in case there is any splash back whenever you are trying to find the right pressure to use. The splash back can easily get in your eyes if you do not use caution and can cause severe eye irritation and even blindness. Safety is something that you should practice with your pressure washer regardless of what you are spraying, however, chemicals and detergents should especially be used with caution.
Start at the Top
Whenever you are working with an area that is especially dirty, it is a good idea to start at the top. Begin at the roof and work your way down to the floors, pay special attention to the corners and any cracks. It is also a good idea to apply with a knapsack sprayer. It is a good idea to apply the detergent to a dry area whenever you are beginning. A 45 degree jet angle will be necessary as well as a setting that is right around 500 psi or 35 bars.
1. Pressure
2. Safety
It is very important that you practice safety whenever you are working with your pressure washer. Whenever you are applying detergent, you will need to make sure that you are wearing gloves as well as protective clothing. It is also a good idea to wear goggles in case there is any splash-back whenever you are trying to find the right pressure to use. The splash-back can easily get in your eyes if you do not use caution and can cause severe eye irritation and even blindness. Safety is something that you should practice with your pressure washer regardless of what you are spraying, however, chemicals and detergents should especially be used with caution.
3. Start at the Top
Whenever you are working with an area that is especially dirty, it is a good idea to start at the top. Begin at the roof and work your way down to the floors; pay special attention to the corners and any cracks. It is also a good idea to apply with a knapsack sprayer. It is a good idea to apply the detergent to a dry area whenever you are beginning. A 45-degree jet angle will be necessary as well as a setting that is right around 500 psi or 35 bars.
