4 Attic Storage Container Insulation Tips
An attic full of junk.
  • 1 hours
  • 25
Plastic bins
Plastic bags
Caulking
Blankets
Padding beads
Plastic bins
Plastic bags
Caulking
Blankets
Padding beads
If you are going to be using your attic as a storage space, you will need to insulate your containers to withstand any temperature changes and potential moisture that may get trapped within the attic. Below are some insulation tips to consider.
Tip 1 - Use Plastic
Plastic is an insulator. Polystyrene and plastic foam are both used as insulators as small air bubbles in their makeup keep the heat energy from flowing through them. It is strong and easily susceptible to weathering. Clear plastic has the advantage of letting you see what is in each container.
Tip 2 - Line with Blankets
If one of the things you are storing is blankets, consider lining your storage containers with them. That will help provide an extra layer of padding for your items, and it will decrease the chances of the items being affected by temperature changes.
Tip 3 - Caulk the Cracks
If you are using wooden storage containers or any containers that may have cracks in them, consider caulking over the cracks to provide an extra layer of sealant on the outside. If water seeps in from the roof, you will be thankful for the caulk.
Tip 4 - Use Packing Peanuts
If you aren't going to be using the contents of your container for a long time, consider putting packing beads, also known as packing peanuts, in there for insulation. They will fill all the gaps for you.
Pots and pans hanging from a rack in a kitchen.Looking for more storage tips? Here are some storage solutions for small kitchens.
