4 Benefits to using an Airless Paint Sprayer
For any large paint job, an airless paint sprayer can be vital. They are much more effective for large jobs than a paintbrush, and are also better than a roller. Some people are afraid of using these sprayers because o the perceived risk in using them, but as long as you take enough suitable precautions, the airless paint sprayer is a great way of getting your paint project completed on time. So long as you can manage to get the paint job done quickly, there should be no problem. There are many advantages to using the airless paint sprayer over other methods.
1 - Speed and Efficiency
If you have been used to painting items by hand, or with a roller, then you may be surprised by the adaptability of the airless paint sprayer. The brush is a good way of filling in details, but when you have a lot of work to do, it can be exhausting and time consuming. The paint roller is quicker than the brush, but it has a tendency to leave horrible streaks that mar the paintwork of your room. The airless paint sprayer is better than both of these old methods, meaning that you can get the job done much more quickly than you would expect.
2 - Uniform Application
The sprayer is also perfect for areas which are not ideal, such as textured walls, popcorn-effect ceilings, or other uneven effects. You can Use the sprayer to provide a uniform application of paint which will allow you to get more out of your room. You will not have to stop and start, as you do with ordinary painting methods, so you can get it done, and move onto the next job. Applying even layers also means that you avoid the unnecessary riding and streaking of rollers and paintbrushes.
3 - No Compression
While the airless paint sprayer is not the only paint machine on the market, you should know that many of the latter use compression techniques to drive the paint through the nozzle. This is not true of the airless sprayer, which uses a hose method to push the paint outside, rather like using a pressure washer on your car. This prevents the overspray problem which mainly paint machines have, and you can also control the flow of the spray, so it does not go everywhere.
4 - Portable
While brushes and rollers are easily movable, most large paint machines are very difficult to manipulate, and sometimes take more than one person to move them around a room. The airless paint sprayer is placed on a cart, which not only means that yo can move it about the room, but also lift it in and out of the home, so it can be moved into storage when it is not needed. They are usually small for their ability, with a motor which is under 1 horsepower, so you don't have to worry about heavy engines.
