4 Best Ways to Heat Your Garage Workshop
If you use a garage workshop during the winter, you may need to install a heating source. Here are the best ways to keep your workspace comfortably toasty throughout the chilly season.
1. Infrared Heater
One of the best ways to heat your garage workshop is to use an infrared heater. You can get infrared heaters that are powered by propane, natural gas, or electric sources. For the garage, you may want to consider an electric heater so that you do not have to worry about ventilation.
The great thing about infrared is that it does not use as much power as a traditional heater. This type of heater actually heats up the objects around it instead of heating up the air. It works in much the same way as the sun as it sends rays to the objects and heats them up on contact. One small heater may not heat the entire garage, but if you point it at your workstation, you should be warm.
2. Wood-Burning Stove
Another option that you may consider is a wood burning stove. With this type, you will need to install proper ventilation so that the smoke can get out of the garage.
By using a wood burning stove, you will be able to significantly increase the amount of heat that you are able to produce. Wood is also cheaper than most other heat sources. The only downside is the need to constantly add wood. It takes a little more work than other options.
3. Radiant Heat
Radiant heat is more complex solution, and requires the installation of water pipes in walls or in the floor of your garage. The system heats up the water and runs it through the pipes. It then transfers heat into the surrounding air in the garage.
This project can be expensive and time-consuming, so it may not be practical for some applications. However, once this system is installed, it can be the most economical option available.
4. Natural Gas
Another option worth considering is a natural gas heater. Similar to wood burning stoves, this type of heater also requires ventilation. This heater also needs a constant supply of natural gas, which can be handled either by installing a dedicated gas line to the unit or by attaching a stand-alone gas tank to be refilled as needed. This heater produces a large amount of heat for optimum comfort during the coldest months.
