4 Home Remedies for Mildew Odor Removal
Beginner
- 1-20
There are different mildew odor removal methods that you can try using common household items. With these simple home remedies, there is no need to get strong chemical solutions that may have harmful effects to your health.
1. White Vinegar
Clothes stuck for a long time in storage can have mildew odor, but there is a simple way to remove the smell without using chemical solutions. White vinegar is a natural product that you can use. The acidity in the vinegar is a great deodorizing ingredient since it attacks the molecules that create the scent.
To remove that mildew stench using white vinegar, add one cup during the cold water rinse in the washer but do not use any detergent powder. When complete, wash the clothes using the normal process.
2. Baking Soda
Just like white vinegar, baking soda is a great natural product to remove any smells due to mildew. It also has deodorizing components that attack and neutralize acidic molecules. There are several ways you can use baking soda as a deodorizer.
Baking soda can serve as a natural air freshener in places where the odor of mildew is more frequent, like basements, attics, closets, cabinets, or any damp and enclosed areas. All you need to do is open a box of baking soda and place it in these locations or you can put an adequate amount in a container, making sure that it is open to allow air to circulate through. This use for baking soda is so common that some boxes of the substance are designed to open on the sides to allow for the best air movement.
You can also use baking soda to remove any mildew odor in your clothes or towels. Just add a few spoonfuls of the baking soda to each laundry load, and it will easily remove the smell.
3. Cat Litter
Another uncommon, yet effective, home remedy that you can use to remove the smell of mildew is cat litter. Cat litter has ingredients designed to mask the smells of cat waste, so it’s only natural that it would be a very effective deodorizer for other purposes. Place a box of cat litter in the areas when the mildew scent is most common, making sure that the box is open. In effect, the cat litter will act as a natural air freshener.
4. Hydrogen Peroxide
Hydrogen peroxide is another solution that you can use to remove that musky smell in your home. It is advised, though, that you avoid using this strong chemical solution as a deodorizer for clothes or any soft material or surfaces, as it may ruin the fabric or cause stains. Hydrogen peroxide has very strong oxidizing properties making it a good bleaching product so extra precaution is needed when using this solution.
Create your own deodorizer using hydrogen peroxide. In a sprayer, mix one part hydrogen peroxide and two parts of water. Make sure that you use a three percent hydrogen peroxide solution. Spray this solution in areas where the mildew or musty odor is present. Be sure not to spray any surfaces that will react with the solution, and allow it to sit for a few hours to work properly. You can also use this solution to remove the mildew smell from drawers, sofas, or any heavy-duty items. Leave it for a few hours before you rinse the material and the smell should be neutralized.
