4 Home Remedies for Mold Removal
moldy, rusty bathtub with rubber duckies
You don't always need professional help for your mold removal projects. There are certain home remedies you can do that are as effective as any chemical product professionals would use.
Below are some home remedies you can use to remove mold growth in your home.
1. Soap and Water
Believe it or not, soap and water are effective in removing mold if the growth is not too deep or too severe. All you need to do is scrub the affected area with a strong cleansing soap and water.
2. Chlorine Bleach
Chlorine bleach is also an effective solution in removing molds. Chlorine bleach contains hydrogen peroxide, which has strong oxidizing properties, so handle it with care and keep it away from children and pets. This chemical solution also contains strong anti-bacterial properties, as well as sterilizing and disinfecting properties. The solution is also an effective way to remove black mold, which is one of the more toxic types of mold.
To use chlorine bleach as a mold removal, mix a cup of bleach into a gallon of water, making sure the mixture is well incorporated. Place the solution in a spray bottle and spray it on to the surfaces where mold is growing. It is important to remember that this remedy can not be used on surfaces that may stain or react with the bleach, including metal, cloth, and wood. Because of the bleaching properties of chlorine, the surface may be ruined or stained.
3. Tea Tree Oil
liquid coming out of a spray bottle
Tea tree oil is an uncommonly known ingredient for removing mold in your home. Although tea tree oil can be quite expensive in large quantities, it is an effective, all-natural home remedy for removing mold.
Tea tree oil has antibacterial, anti-fungal, antiviral, and antiseptic properties, making it a strong ingredient. As a result, using tea tree oil as a home remedy to remove molds should be done with care. In its pure form, it is toxic if ingested and can cause severe internal damage.
All you need for this home remedy is one teaspoon of tea tree oil and two cups of water. Pour both liquids into a container or spray bottle. Mix well to combine the two ingredients. Spray or apply the solution to the affected areas and let it sit and dry out.
This solution is great for almost any item, including cabinets, walls, drawers, and clothes. The smell of the tree tea oil can be strong at first, but after a few days the smell will dissipate on its own.
4. White Distilled Vinegar
white vinegar in a bottle
If white vinegar is an effective ingredient to remove the smell of mold or mildew, it only makes common sense that it will also be a great ingredient for killing and removing mold. However, you do need to use white vinegar in its pure form without mixing it with water or other liquids. In some cases, white vinegar can kill about 82% of mold, making it an effective home remedy solution.
Just pour or spray the white vinegar in the affected area and let it sit. Do not rinse the area once the vinegar has dried up. After a few hours, the mold and the acidic smell from the vinegar will disappear.
