4 Recycled Materials Used for Aquarium Stands
a person holding an empty aquarium
Aquarium stands are something that can be a real thing of beauty in your home. You will find that they can also be very expensive. However, being able to find recycled materials for your aquarium stand is something that you can do to save money and help out the environment. Many aquariums are put onto stands unless they are actual tower designed aquariums. This means that you more than likely are going to have to worry about getting a stand for your aquarium.
Wood
Wood is something that you can easily find recycled. You will be able to get scraps of wood together and create a unique aquarium stand. You will simply need to make sure that the wood that you do use wood that is water resistant. This means oak or teak. Purchasing these types of wood is very expensive so it may be a little tricky to find the right type recycled. It will definitely save you some money if you are able to fine it though.
Wood by-Products
Wood by-products are simply recycled wood. This is something that has been made by compacting wood that has already been used into pressed boards. This is the easiest way for you to go about finding recycled wood for your aquarium. The outer layer of these wood by-products is then protected with a resin that is used to help protect this wood from water damage. These products are not as sturdy as regular wood so they cannot handle as heavy as a load. However, they are much less expensive and are completely recycled.
Metal
Metal is another popular type of material that is used for aquarium stands. Typically, steel or iron that is coated in layers that is water resistant to prevent any rust. Even with this protection, these types of materials are still prone to rust over time this is especially the case with saltwater aquariums. Whenever you are looking for recycled steel or iron materials for your aquarium, make sure that you know that they are coated in water resistant layers. If they are not, then this is something that you are going to have to do yourself.
Other Options
You can always use things that you already have around the house. Reusing materials that you already have is basically recycling your own materials. You can always use a table that you never use anymore if your aquarium can fit on it. Many people do not like to use tables because they do not feel that they are as presentable. However, it is all in how you present it yourself. Dress up the table and make it look like an aquarium stand instead of like a regular coffee or dining room table. Use an old entertainment center that you have no use for. If the aquarium fits in the entertainment center then it can really look like it was made specifically for the use of holding an aquarium. When you are short on money or want to use recycled products for your aquarium stand, start by looking around your home.
An aquarium stand can be a real thing of beauty in your home. You will find that they can also be very expensive. However, being able to find recycled materials for your aquarium stand is something that you can do to save money and help out the environment. Many aquariums are put onto stands unless they are actual tower designed aquariums. This means that you more than likely are going to have to worry about getting a stand for your aquarium.
Wood
Wood is something that you can easily find recycled. You will be able to get scraps of wood together and create a unique aquarium stand. You will simply need to make sure that the wood that you do use wood that is water resistant such as treated oak or teak. Purchasing these types of wood is very expensive so it may be a little tricky to find the right type recycled.
Wood Byproducts
Wood byproducts are simply recycled wood. This is something that has been made by compacting wood that has already been used into pressed boards. This is the easiest way for you to go about finding recycled wood for your aquarium. The outer layer of these wood byproducts is then protected with a resin that is used to help protect this wood from water damage. These products are not as sturdy as regular wood so they cannot handle as heavy as a load. They are much less expensive than hardwood and are completely recycled.
a colorful aquarium in a classroom
Metal
Other Options
