4 Tips for Choosing an Asbestos Testing Kit
Asbestos is still found in older homes and buildings which makes an asbestos testing kit important. Asbestos, if left unchecked, can cause many health issues. Removing asbestos is a huge job that is expensive, but has to be done. If you feel that your home may have asbestos siding or insulation, then you need to use an asbestos testing kit or call in a professional to know for sure. There are many asbestos testing kits on the market. There are a few factors to consider in deciding which kit is the right fit for you.
1. Cost
You can find an asbestos testing kit for as little as $14, but they can also be found for prices well over $100. In this case, price does not necessarily mean quality. Always set a budget when you go shopping for an asbestos testing kit to avoid paying too much for a product that may not work as well as you would like it to.
2. Immediate Result Kits
Getting ill from asbestos is not an overnight thing. If you want to know right away that your house is safe, then an asbestos testing kit that gives results quickly is right up your alley. There are many different types of asbestos testing kits that give immediate results. One problem with these types of kits is that you have to rely on yourself to do the test correctly. These tests are all-inclusive which means you have a sample pouch and a chemical agent. It is your job to scrape off a piece of siding or insulation from your home and place it in the pouch. You then add the chemical to the pouch and wait a few seconds. You then have to read the results accurately. The kit's instructions will tell you how to do so. You also have to make sure that the asbestos testing kit is completely sterile.
The main issue you will have with an immediate results asbestos testing kit is that they are not always that accurate. This inaccuracy can be attributed to many factors including the age of the kit you purchased.
3. Lab Result Kits
A man in a hazmat suit removes siding covered in asbestos.
Lab result kits do not have the same accuracy issues as immediate result kits. These kits require you to send a sample to a lab. You simply scrape away a sample of the siding or a few fibers of insulation from your home and place it inside a sample pouch. You then take the sample pouch and send it off to the lab using the shipping pouch the kit provided.
4. Contents
One thing you need to consider is what comes in the asbestos testing kit. Never buy a kit that has no expiration date on it or a kit that has you using household items. Only buy an asbestos testing kit that includes everything you need but also one that is fresh.
Asbestos testing kits are a great way to know whether your house has an asbestos problem. If it does, act on it immediately. You may not notice the effects of asbestos until you are already ill.
