4 Tips for Installing a Radon Gas Detector
A radon gas detector.
A radon gas detector is a small piece of equipment that can play a big role in your life. Radon is a very dangerous gas that can cause health problems for you and your family. It is one of the leading causes of lung cancer today. Therefore, anything that you can do to protect yourself from radon should be done. Having a radon gas detector will help you to know if the dangerous gas is in your house. Installing a radon gas detector is very simple and usually takes only a few minutes. Here are a few tips for installing a radon gas detector quickly and effectively.
Check the Batteries
When you get a new radon gas detector, you should check to make sure that it has batteries. Open the battery cover and make sure there are some in there. If you have a battery tester, you should probably check to see how much of a lifespan the batteries have left. If they are drained, you will want to make sure that you get some new batteries to put into it.
Work in Pairs
It is usually best if you get two radon detectors to install in your house. Just one radon gas detector may not be able to pick up gas from another part of the house. Putting one in the main traffic area of the house, like a living room, is usually a good idea. Then take the other radon gas detector and install it as close to the ground as you can in your house. If you have a basement, that would be the ideal location for one. If you do not have a basement, just make sure that you put it on the lowest level of the house. Radon is formed when uranium breaks down in the soil. Therefore, you want it to be close to the soil in order to see if any radon is leaking into the cracks of the house.
Put it in Place
You will want to pick an area that is out of the way and free of obstructions. Put the radon gas detector on an interior wall. You will want to make sure that it is not near any heating sources or drafts so that it does not give you a false positive test. It can sometimes pick up on other gases along the way and end up having problems.
Leave it Alone
Once you get the radon gas detector in place, you need to make sure that you leave it alone for an extended period of time. Many people put it in and then start messing with it immediately afterward. Just make sure that it is turned on and then let it set alone for at least a week. Radon detectors take measurements of the air and then average out the readings to determine if the radon levels are unsafe. It will take at least 7 days to get a good reading from a radon detector.
