4 Tips for Installing a Shower Splash Guard
When you spend a small fortune to renovate or upgrade your bathroom, the last thing you want to do is ruin your floors, and this is where a shower splash guard can help you. A shower has the capability of making someone feel relaxed and it is an unfortunate side effect when you get a wet floor. When water gets on the bathroom floor, it can cause slip and fall accidents as well as cause ruin to the floor. Installing a shower splash guard can help prevent too much water from splashing out of the tub, and the following tips will help ensure a successful installation.
1. Size Is Everything
Not every tub or shower is the same size, and getting a shower splash guard that will work correctly hinges on size. The excess water can be prevented, but only if the correct shower splash guard is used. The most important dimension of the shower splash guard is the length. Measure the length of the tub starting at the wall. When you go shopping for a shower splash guard, you can take this measurement along with you to get the one that will correctly do the job.
2. Start with a Clean Surface
Most shower splash guards come with their own adhesive, which is covered by a piece of paper. This type of adhesive is made to stick to just about anything, and continue to stick for a long time to come. The problem with working on shower tile is that over time it gets a buildup of water, grease and residue. To keep the adhesive backing of the shower splash guard effective, you need to clean the bathroom tile where it will be installed. Use a mild soap mixed in water and a spray bottle. Spray the area and wipe it down with a towel. This will make an area where the adhesive will make a strong bond on the tile.
3. Soap Residue
The residue left behind from soap can cause a shower splash guard to stop sticking to the tile. Even after you've cleaned the tile, the soap residue may still remain. A great product to take soap residue off the wall to make sure there is a surface to stick to is rubbing alcohol. Pour some rubbing alcohol on a cotton ball, squeeze out the excess and scrub the wall. Use a lint-free towel to wipe away the alcohol.
4. Line It up Right
One problem that messes with the effectiveness of a shower splash guard is where it is placed. Don't put it on the outside edge of the shower or tub. That extra lip allows the water to pool, circulate and then find a way to pour down the outside of the tub. The best place for the shower splash guard is in the outside corners of the tub, as close to the inside lip as possible. Press them tight against the wall tile and apply strong pressure.
