4 Uses for Oxalic Acid
Rust stains on a painted metal plate.
Oxalic acid is an essential household chemical that can be used, like many acids, as a cleaner for various things such as a rust remover, a cleaning agent, a stain lifter on woodwork, and as a bleaching agent.
This acid is a natural component of plants and vegetables such as buckwheat and rhubarb and is available for purchase in powdered form at your local home improvement depot. The oxalic powder is then mixed with water to turn into a solution of oxalic acid. At high doses, oxalic acid is very dangerous, but at moderate doses, it is safe for various useful functions.
1. Bleaching
Oxalic acid can be used as a bleaching agent for both wood and stone. Wood, when exposed to the elements, can turn gray. When oxalic acid is applied on an old and graying wood floor, it brings back the wood floor’s natural white color. As a result, this acid is often used when preparing to stain old wood floors. It is also used by furniture manufacturers to lighten heavily stained areas of wood furniture in preparation for refinishing.
2. Removing Stains
Oxalic acid effectively removes ink, food stains, and many other types of stains. It is a gentle stain remover that eats the stain but leaves the base surfaces, such as wood, intact. You can use oxalic acid to remove most stains found on stone, brick, linoleum, wood, and vinyl surfaces.
Do not, however, use oxalic acid if your flooring is sealed as it will eat through the finishing.
Although you can also use oxalic acid to remove stains from fabrics such as linen and cotton, it will take a lot of time, so it is better to have your fabrics dry cleaned instead.
3. Removing Rust
Oxalic acid is also used to remove rusts that are commonly found on plumbing pipes and kitchen countertops, and is a major ingredient found in commercial rust removers for sinks, tubs, and rust stains.
4. Other Uses
Aside from bleaching, rust removing, and stain removing, oxalic acid is also used as a reducing agent in developing photographic film. You can also find it used in wastewater treatment as well since oxalic acid can effectively remove calcium from wastewater. Oxalic acid is also used as a grinding agent when polishing marble.
Safety Precautions
Oxalic acid in its pure form is very dangerous. It is toxic and corrosive and should be carefully handled. When mixing the powdered acid with water, always wear latex gloves to protect your skin. You should also use protective glasses and a dust mask to avoid eye irritation and to prevent the noxious fumes from getting into your lungs.
Always mix oxalic acid in an area that is well-ventilated—preferably outdoors. In case of accidental swallowing, never induce vomiting; instead, contact your physician or your local poison control center immediately.
