7 Waterproof Bathroom Wall Options
Having waterproof walls in your bathroom is important. If the walls are not waterproof, you could end up having a huge problem on your hands, such as mold, leaks, water damage, and more.
There are a few options when shopping around for new bathroom walls that are waterproof. Things to consider will not only be the price, but also which material, color, shape, pattern, and installation process you prefer.
1. Single-sheet Plastic
You can buy single-sheet plastic for your bathroom walls in a variety of colors and styles. This is often the cheapest option and one a lot of people use. There are a number of different plastic-sheet walls available on the market today in a range of prices.
2. Tile
Traditionally, tiles can come in a number of different materials including marble, slate, ceramic, porcelain, and more. A lot of people prefer tile over single-sheet plastic because it looks more elegant and expensive, but doesn't necessarily have to break your budget.
A fully-tiled wall will help ensure your bathroom is waterproof while also making a statement. You can even continue the tile onto the floor for a continuous look. You can purchase tiles not only in a number of different materials, but also in different shapes, sizes, colors, and patterns. A lot of people prefer marble, stone or granite when selecting a tile for their bathroom.
Not to mention, a lot of stores make it easy for you to install tiles yourself now because they can come in pattern-ready sheets that you simply apply, rather than working one piece at a time.
Selecting the right tile can turn your bathroom into the center of attention, rather than leaving it plain and drab.
3. Acrylic
These are the most common waterproof bathroom walls. You can buy bathroom walls to go around your tub or shower that are made with acrylic. These walls come in a wide range of prices, shapes, and styles, but are usually white or off-white. A lot of single-sheet plastic walls are also made from acrylic, but you can get full pieces as well that are easy to install yourself.
Most tub surrounds are made from acrylic and are bought in 3-piece direct-to-stud packages. The nice thing about these waterproof walls is that they not only are super easy to install yourself, but also feature built-in shelves.
4. Laminate
Again, laminate is another type of bathroom wall that can be purchased as a single-sheet or as tiles, and it is very popular. Laminate walls can either come in a high-gloss, glass-like finish or in a more traditional look, which is a great option to match your waterproof bathroom walls to your entire house, depending on whether your home is more modern or old-fashioned.
The great thing about laminate walls is that they are lightweight, easy to install, and can last for years. They also come in a bunch of different colors and patterns, which is great for people who want something more unique and interesting compared with plain white.
5. Stone
To achieve a high-end look, some people prefer to install stone walls in their bathrooms. Stone walls add a natural, yet exotic, look and feel to your bathroom, giving off a relaxing vibe.
Stone walls are waterproof and look really cool. However, real stone can be very expensive and difficult to install yourself, depending on the style of stone. Luckily, if you prefer stone walls, you can purchase natural stone tiles, which still look very sleek and modern.
6. Glass
Another option for waterproof bathroom walls would be to install glass walls.
Glass is definitely waterproof, but not always realistic. Still, it is very futuristic looking, which is kind of cool. People often install glass shower walls, but you can install glass walls for your bathtub or even your entire bathroom if you like.
Although glass bathroom walls certainly eliminate privacy, they do make a space feel open, which can be fantastic if you live out in nature and want to enjoy the view, but kind of odd if you live around a lot of people.
7. Paint
When painting your bathroom, it's important that you use the right kind of paint. You should use waterproof coating paint to make sure no water damage happens.
Waterproof paint should be oil-based. Painting your bathroom with waterproof paint is no different than any other paint, just make sure to keep the room well-ventilated and dry until the paint is completely dry.
Bonus Tip: Always Use Sealant
No matter what wall you choose, it's important that you use the proper sealant for it. Sealant helps keep moisture and water from going in between cracks in the wall. Make sure to follow the instructions for the best results, and always use silicone caulk with it as well for the best protection.
