5 Advantages of Fiberglass Subwoofer Enclosures
Fiberglass subwoofer enclosures are popular means of housing subwoofers. Aside from protecting the subwoofer, a fiberglass enclosure can improve the sound quality of any speaker system. It is also quite easy to make a customized fiberglass subwoofer enclosure. A fiberglass subwoofer enclosure provides a lot of advantages in any audio car set-up. Fiberglass subwoofer enclosures can fit in any vehicle or vehicle space. Unlike a normal rectangular enclosure, fiberglass subwoofer enclosure can make do of any irregular sized space. Also, most car owners prefer fiberglass subwoofer enclosure because it presents a customized look. Those who use fiberglass subwoofer enclosures can boast of a car audio system that is truly unique and eye catching. There are other benefits of using fiberglass subwoofer enclosures including the following:
1 - Saves Space
Perhaps the best advantage provided by fiberglass subwoofer enclosures is in terms of space. Fiberglass subwoofer enclosures can be designed to fit inside any shape and space available. This is in stark contrast to the wooden enclosures that are designed to fit in the size of the trunk. Having a fiberglass enclosure for the subwoofer can maximize the space available in any vehicle. Aside from saving space, vehicle owners can also have a lot more options in enclosing their subwoofer.
2 - More Variety in Design
Another distinctive advantage of using subwoofer enclosure made of fiberglass is the wider variety of available designs. Most wooden enclosures are shaped either like a rectangle or square. On the other hand, a subwoofer enclosure made of fiberglass can be designed into more elaborate styles. Fiberglass subwoofer enclosures can also blend seamlessly into the vehicle; this makes a customized audio car setup more stylish.
3 - Lightweight
A subwoofer enclosure made out of fiberglass is also a lot lighter compared to those made of wood. Wooden subwoofer enclosures are known for being heavy, adding a lot of weight to the load being carried by a vehicle. Another problem of heavy wooden subwoofer enclosures is that it can be very difficult to move them around whenever needed. On the other hand, a fiberglass subwoofer enclosure is very light in weight, meaning they can be moved around easily. Fiberglass subwoofer enclosures also do not add up a lot of weight on the load of a vehicle that could have meant more fuel consumption.
4 - Better Sound
Audiophiles agree that using a fiberglass enclosure for the subwoofer results to better sound quality for any car audio set-up. Typically, fiberglass subwoofer enclosures are custom-built for a vehicle, so there’s a greater likelihood that the speakers will sound better with fiberglass enclosures.
5 - More Durable
Finally, a subwoofer enclosure made of fiberglass is more durable and a lot stronger compared to its wooden counterpart. Wooden subwoofer enclosures are usually manufactured from medium density fiberboard of MDF; this material has a lower strength to weight ratio compared to fiberglass. Thus, fiberglass subwoofer enclosure is a lot stronger and consequently more durable compared to wooden enclosures.
