5 Advantages of Using a Sheet Sander
1 hours
Beginner
- 30-100
A sheet sander is a tool that is easily held in your hand, and which accepts normal sandpaper. The beauty of sheet sanders is they are very versatile. This means you can use it to sand and smooth out a variety of surfaces including wood, metal, and plastic. It all depends on which type of sandpaper you choose to use with the sheet sander.
Orbital sanders and sheet sanders do the same thing but operate differently. An orbital sander operates in a random elliptical manner while a sheet sander uses a circular motion. Many industries make use of the sheet sander from construction projects to installing drywall. The following article will share with you some of the best uses for a sheet sander.
1. Easy to Use
A sheet sander is incredibly easy to use in order to add a finished touch to whatever material you are using it on. When you properly use the sheet sander you will be able to work out shapes and smooth a surface in no time with little effort. When you start using the sheet sander it is important to hold it straight. Do your best to not tilt the sander and use slight pressure. A sheet sander is an aggressive tool which means you need to use complete control. Without a sheet sander as your disposal the job of sanding would take much longer to finish.
2. Residue Removal
Some surfaces are very prone to get some sort of residue on it. The residue can be some sort of oil either from the area around it or by our own use. Other residue can involve unwanted paint or polish of some kind. A sheet sander can be used to remove this residue from the surface you are working with.
3. Speed
Normal sanding would involve either a sandpaper block or a handle with clips you can attach sandpaper to. The sheet sander will get a job done and done quickly. Sanding the old fashioned way could take hours while a sheet sander will cut the time in half if not more.
4. Versatility
A sheet sander can either be hand held or used as a floor type of sander. This means you will be able to use the sheet sander to polish floors or sand them down in order to properly finish them. You can also use the sheet sander to sand down furniture, walls, and counters. The primary size, however, is fairly small so it fits into the palm of your hand.
5. Cost and Substance
An electric sander is a tool that can be used a lot around the house as well as around a construction site. Many of these electric sanders can cost a lot of money which some people may not have. A sheet sander is one of these tools that are small and relatively inexpensive. Most of the tools you find will not live up to their expectations but a sheet sander is a tool that will despite its low price.
