5 Easy Ways To Remove Household Mold
In order to remove house mold there are several different strategies that you could take. Mold inside your home can be a serious problem for you. It can cause health concerns for the inhabitants as well as decimate the value of the property if it spreads throughout. Taking care of mold when you first notice it is very important. Here are a few easy ways to remove house mold.
1. Use Chlorine Bleach
Using chlorine bleach is one way to help remove mold. However, it will not work in all situations and in all surfaces. You should only use chlorine bleach if the mold is growing on a non-porous surface. For example, if you have the mold in your bathroom on a hard surface such as a bathtub or countertop. If you have mold on wood, chlorine bleach will not work because properties in the bleach prevent it from going deep down into the wood and killing the roots of the mold. You can use bleach to disinfect the area after you remove the mold, but on porous surfaces, you should stay away from chlorine bleach.
2. Detergent
borax
One thing that will work on porous surfaces is detergent. One common ingredient in many laundry detergents is borax. Borax is great for penetrating deep into porous surfaces and eliminating mold and other materials. Therefore, if you have mold on wood or another porous surface, this would be a great product to use. You can mix it with water and form a nice compound for removing mold quickly and efficiently. Scrub the area with this mixture and a scrubbing brush to remove the mold. Then you can disinfect it with chlorine bleach after.
3. Grapefruit Seed Extract
If you are looking for a natural way to eliminate the mold for you, grapefruit seed extract may be the way to go. Take two cups of water and add 20 drops of the extract to it. Mix it up and you have a very powerful mold remediation mixture. Take this mixture and scrub the mold with it and it should eliminate the problem.
4. Vinegar and Baking Soda
vinegar and baking soda next to a bucket
Many people keep vinegar and baking soda around the house for a variety of different reasons. When you combine these two things together, you come up with a great mixture for eliminating mold. First, take water and vinegar and mix them together in equal parts. Then take two parts of baking soda and mix all of that together. This should make a paste that is pretty thick. Put it onto the surface with the mold and let it dry. Then take a scrub brush and scrub it off of the surface. Do this as many times as it takes to remove the mold from the surface.
5. Hydrogen Peroxide
Another common household item that can be used to remove mold is hydrogen peroxide. Mix one cup of warm water with 1/2 cup of hydrogen peroxide. Then scrub the surface of the mold with this mixture to remove it.
