5 Reasons to Choose a 1-Piece Toilet Over a 2-Piece Toilet
1-piece toilets and 2-piece toilets share many things in common. They both serve the same purpose, and most of them go about it by flushing the same way. They are both installed using relatively the same methods, and they both use the same amount of water. 1-piece toilets do have a few advantages over 2-piece toilets.
Size Differences
A 1-piece toilet is generally smaller than a 2-piece toilet. The tank is connected and sits lower on the bowl than on a 2-piece. Due to the smaller size, 1-piece toilets are able to be installed in bathrooms with less square footage that do not have as much space as a normal bathroom. They are often the toilet of choice for disabled people and households with young children, since they sit lower to the ground and the handles are placed lower. A 2-piece toilet may be more ideal for adults or elderly individuals, since they sit higher from the ground.
Ease of Cleaning
Due to the fact that 1-piece toilets have fewer nooks and crevasses than 2-piece toilets, they are easier to keep clean. It is also easier to reach certain areas since they are lower to the floor, which makes them more difficult to repair on your own.
Durability Factor
Since 1-piece toilets are 1 solid piece of ceramic, fewer of the pipes and flushing elements are exposed. That protects them from outside elements, such as excess moisture. As with most equipment, the fewer separate parts that comprise it, the more durable it proves to be.
Price Points
1-piece toilets are generally more expensive than 2-piece toilets because they are more solidly constructed. They also have a more modern feel. You may take into consideration when replacing your toilet that because they are more durable than a 2-piece toilet set.
Installation Notes
Since you are only dealing with a single piece, installing a 1-piece toilet is generally easier than its 2-piece counterpart. They are also more bulky and unwieldy than a 2-piece, so you may want to consider the amount of space you are working with, as well as how many hands you will have helping with the installation. Carefully follow the installation instructions regardless of which toilet you choose.
After all is said and done, a new toilet is inherently a very personal choice. Consider your personal comfort and taste before placing too much stock in price and ease of installation. A new toilet should be a long term addition to your home, so make sure you get something you’ll be happy with for years.
