5 Tips for Cleaning a Fiberglass Shower Floor
fiberglass bath and shower
  • 2-6 hours
  • $0-100
Sponge
Cloths
Vinegar
Baking soda
Floor polish
Wax
Mild detergent
Bleach
For some people, cleaning a fiberglass shower floor is a relatively easy task, but for others, it can be quite cumbersome. The presence of moisture in the bathroom may gradually result in an accumulation of mineral deposits and soap scum on the shower floor. Over time, fiberglass floors may also become faded and dull due to weathering. Here are 5 tips for cleaning a fiberglass shower floor.
Preventing Mildew Growth and Soap Scum
The best measure of prevention is to wipe the fiberglass shower floor with a small sponge or cloth after showering so that the soapy water does not dry on the floor. You may also improve the ventilation system within the bathroom by turning on the exhaust or opening the window; moreover, it is advisable to use liquid soaps or shower gels instead of a soap bar, as the latter contains talc, which contributes to the development of soap scum on the shower floor.
Use Vinegar for Cleaning
In order to clean the shower floor, it is recommended that you use environmental friendly products, such as vinegar, which is easy to find at home and an excellent alternative to commercial products due to its acidic property. It is a good idea to spray the floor with vinegar and let it sit for 15 minutes before cleaning it with a sponge.
Use Baking Soda
Having sprayed the fiberglass shower floor with vinegar, you may also sprinkle some baking soda on its surface. The baking soda and vinegar will combine to make a foamy liquid which can be brushed onto the floor with the help of a sponge. For any tough deposits, apply a thick layer of baking soda on an old toothbrush to scrub them off.
Use Detergent and Household Bleach
To give your shower floor a glossy look, add a cup of household bleach and detergent to a bucket of hot water. Bleach will also remove any other tough stains present on the fiberglass shower floor. Don't forget to open windows and put on a respirator mask before you mix the bleach to avoid breathing in its fumes.
Once done, rinse with water and let the floor dry. If any of these products are unavailable at home, you may also use liquid dishwashing soaps or even shampoos to clean the shower floor.
Use a Polish
If the fiberglass shower floor in your bathroom has weathered and faded, use a soft cloth to apply some polish to a small area on the floor. The correct method of application is to use a gentle circular motion to rub the polish on the floor for a smooth and glossy finish. After polishing, it is advisable to use a coat of wax on the floor to protect the surface in addition to enhancing the gloss. In the absence of a floor wax, you may use car wax as an alternative, but be sure to let it dry before walking on the floor.
