5 Tips for Drilling Drywall Screws
Drywall screws are used for installing drywalls more effectively. A drywall is usually made from gypsum plaster that has been pressed between two thick sheets made of paper and then dried in a kiln. But a lot of the panels use fiberglass instead of paper because the material can withstand molds, which common in paper that has been exposed to water and moisture. The method of installing drywalls for interior walls and ceilings instead of plaster finishing became more popular because the process of installing them is faster. There is also less drying and labor time and the construction is relatively easier to do.
Why Use Drywall Screws Instead of Nails
It used to be that drywalls are nailed into place but the method creates circular bumps after a time which is called nail pops. Drywall screws would never pop up, which is why they are better to use for drywalls. Furthermore, the screws can hold the drywall better and you can always remove them and do it again should you make a mistake. To make it easier for you, you can consider purchasing or renting an electric screw gun instead of doing a tiring task of placing each screw using a Philip screw. The electric tool also has a magnetize tip which holds the screws in place, and they sink screws to the right depth.
The Right Screw for the Job
You can buy drywalls in different thickness. It is essential that you use screws that will go through the thickness of the material, and will sink enough into wood to hold the drywall securely. Hence you must always select the size of your drywall screws based on how deep you want them into wall studs.
Setting Depth for Drywall Screws
For repetitive attachment of drywall screws, a power drill is recommended. Use a drill with a clutch that can be adjusted so that you can set the depth that you want each drywall screw to be driven. If you drive the screws too deep into the drywall, it will break the paper or fiberglass surface, and you will have to adjust the clutch again. To ensure that you have the proper setting, try it on a scrap piece of drywall first. Adjust the drill clutch until it can drive screws just underneath the surface of the panel.
Driving Drywall Screws Accurately
To be able to lessen the chances of missing the unseen studs underneath the drywall, mark the location of the studs on the top and bottom of the drywall before securing it in place. With a marking chalk, draw a connecting line between the two points then set the drywall in place. Follow this line and sink a screw every 4 inches. This spacing should be enough to secure each drywall panel.
Choosing your Drywall Screw Thread
A drywall screw can have a coarse or fine thread. Using a coarse threaded screw will suck the drywall panel into the studs. It is also best for most woodwork applications. However, coarse threaded screws usually come with metal burrs that can prick your fingers like thorns. If you choose to use wide threaded drywall screws, it is best to work with working gloves. If you are going to attach your drywall panels into metal, it is best to use fine threaded drywall screws.
