5 Tips for Maintaining Your Metal Shed
A metal shed can serve many purposes. Since most metal sheds are placed outdoors and are exposed to certain environmental elements, it is important that you know how to properly care for it. Below are some tips on how to maintain your metal shed.
1. Make Regular Repairs
One of the most important things you can do to maintain the condition of your metal shed is to do some regular repairs. Although metal sheds are very sturdy, it is not privy to damage. Since metal can dent and collect rust, it is advisable that you repair these damages once you see it happening. To do minor repairs, all you need to do is clean the area and rid of any peeling paint or rust. Then apply a coat or two of clear sealant and rust neutralizer. After, use a good quality primer and re-paint the area. However, if the dents or scratches are small ones, some nail polish will do the trick.
2. Put in Ventilation
Ventilation will allow fresh air to circulate into the metal shed. You must remember that metal sheds can become very hot so it is important that fresh air is allowed to circulate inside. You can breathe and stay longer inside your metal shed if you have proper ventilation. Another important reason why ventilation in metal sheds is important is that it increases the chance of condensation build up without it. If condensation starts to happen then it can lead to rust formation.
3. Choose the Right Location for your Metal Shed
Location is an important factor in keeping your metal shed in good condition. If you place your metal shed in an area where it is regularly exposed to harsh elements then expect that your metal shed will not last longer than it should. Choose a location where the metal shed is not on the receiving end of situations where it is likely to get dented like near a garage or parking space. It is also recommended that you choose a location where the metal shed can be at least partially shaded to decrease the amount of hot air from being trapped inside the shed.
4. Waterproof Your Metal Shed’s Roof
Aside from applying rust neutralizers on your metal shed, you may also want to waterproof it as well. Apply some weatherproof compounds on the roof to ensure that moisture does not seep through the roof and into your shed. Most metal shed manufacturers already coat their sheds with weatherproof coating. You can start waterproofing the roof 3 to 4 months after you have installed it to reinforce the weatherproof compound present.
5. Clean the Interior
To prolong the life of your metal shed, cleaning and repairing the exterior is an important step. However, you must also not forget to clean and repair the interior as well. If you are using the metal shed to store any chemicals or tools then it is important you seal these items properly before storing them to prevent any spills and contamination that can potentially damage the walls of your shed. Clean the tools in your metal shed as well to prevent dust or mud from collecting.
