5 Tips for Selecting a Basement Heater
Basements are naturally cold places, so installing a basement heater is inevitable. Your basement can be put to different uses besides jut being a storage area. It can be converted into a gym, study room, home office, or an entertainment room. During winters, the basement must be kept warm like the rest of the house, so the heating system must be strong and efficient. The key elements to consider while selecting a basement heater are its effectiveness, energy consumption, and environmental friendliness. Below are some tips that might help you decide which type is best for you.
1. Use a Radiant Heating System for Sound-free Heating
Radiant heat
Radiant heating systems are very commonly used in basements. They are clean, energy efficient, and very effective. These kinds of heaters use electricity to function and warm up the basement by heating up the floor from below. Flexible radiation tubes with air or water within are installed under the floor and/or behind wall panels. Through the radiators, the entire floor is heated up, and the basement stays warm. Since the radiator tubes run beneath the floor, they are invisible. The entire heating system is also sound-free. The only downside of the radiant heating system is that it is expensive and difficult to install.
2. Use an Electric Heater for Large Basements
An electric heater is generally heavy-duty and ideal for large basements as they can easily heat the room to 100 degrees Fahrenheit quickly. Inside the heater, there is an element which heats the oil that in turn heats the air in your basement. An electric heater is very economical and easy to use, though unnecessary for a small basement. One also does not have to worry about safety with this kind since there isn’t any exposed element.
3. Use a Baseboard Heater to Save Space
Baseboard heater
A baseboard heater is similar to a radiant heating system in that it heats up the flooring and the warm air rises. In the case of the baseboard heater, cold air is sucked towards the floor and gets heated in a continuous cycle. This is a hassle-free solution involving no real complicated install or ducting. These heaters do not take up too much space either. They are also suitable for different types and sizes of basements.
4. Use Ceramic Heaters for Cost-effective Heating
Ceramic heaters have a fan inside which pushes out hot air created by a ceramic heating element. They also come with added features such as a temperature sensor, air filter, tip-over switch, and anti-freezing. For larger areas, you can buy a ceramic heater that has two heating elements and an oscillating grill. If budget is the main concern, then perhaps ceramic heating systems will suit you best.
6. Use a Propane Gas Heater for Small Basements
If your basement is 300 square feet or smaller, a propane gas heater is perfect. A good thing about these is that they also don’t require duct work or electrical installation.
Ultimately, selecting a basement heater mainly depends on the area that you want to heat. Do you just want to keep a small area cozy or keep the entire basement warm? The answer lies in how you plan on using the space.
