5 Tips for Smoothing Silicone Caulk
A tube of silicone caulking being used to seal the edge of a metal threshold.
Silicone caulk is very useful for sealing bathtubs and other fixtures. It can help stop water and moisture from seeping into joints, but it can be a challenge to apply smoothly and achieve a good, even finish. Fortunately, there are a number of simple methods to ensure your silicone caulk looks perfect almost every time.
1. Masking Tape
The best way to achieve an even bead of silicone caulk is by using masking tape. The tape will keep the caulk from smearing, and it will also give you a straight line to follow as you apply it.
To do this, press a strip of masking tape to the wall above the bathtub and another line to the tub itself. You should allow just enough space between them for a bead of silicone caulk. Also, make sure the tape is straight. When you remove it after smoothing the caulk, you’ll be left with sharp, straight lines even a professional would envy.
2. Smooth with Your Finger
You can actually smooth caulking down easily with your finger, running it in a long line along the bead. This can take some practice since you have to keep an even pressure and try to run along the entire length without stopping, if possible. It can take two or three tries to achieve real smoothness.
But there is a trick to it. Before you begin, wet both your finger and a rag with alcohol. Alcohol is both a cutting agent and a lubricant which means your finger will move easily over the silicone. The caulk will need to be cleaned off your finger periodically as you work so it doesn’t interfere with the smoothing process.
3. Speed
It’s important to start smoothing the bead of silicone caulk before it begins to dry. Once the drying begins, it can be almost impossible to achieve the look you want. You need to approach the caulking confidently and not worry if the bead from the tube is even; when you smooth it out, your fingers will fill in the small gaps.
4. Use a Damp Rag
You might well find some small ridges left after you’ve run your finger down the silicone caulk. To remove these, use a damp linen rag and run it lightly along the bead. This will create a very even, professional finish.
5. Work in Sections
Don’t try and smooth the caulk around a whole tub at once. You’ll achieve much better results if you work in sections. This way, you can proceed quickly and smooth the silicone caulk before it starts to dry and develop a skin.
Allow the caulk in one section to dry before you move on to the next. This means taking more time but the results will be worth it.
