5 Types of Bathroom Sink Faucets
faucet
There are many types of bathroom sink faucets from which to choose. Here are 5 of the most common faucets used in today’s bathrooms.
Widespread Faucets
The widespread faucet is a very flexible type of bathroom sink faucet. It has 2 handles, a spout, and a standard spread. The faucet is designed to have 2 handles. 1 handle controls the hot water supply and the other handle controls the cold water supply. This type of faucet is much easier to clean and offers a more ornamental design that is best suited for aesthetically designed bathrooms. The widespread faucet can be spread from 6-inches to 12-inches.
Center Set Faucets
Center set bathroom sink faucets have a standard 4-inch drill that and 2 handles. These handles are usually mounted on a plate. Center set faucets are ideal for smaller spaces. It is a very economical faucet because the handles are very close to each other; however, its design is also its downfall since it is more difficult to clean or use as compared to other types of faucets. This type of faucet also has a version that uses lever handles.
Single Handle Faucets
Unlike other common types of faucets, single handle faucets only require a single sink hole. The controls for this type of faucet are typically found at the top of the spout or at its side. The spouts can be of different lengths as well. The length of the spout varies depending on its designated use. Sink types such as the vessel sink require a longer spout. When purchasing this type of faucet, you will notice that some designs have a 6-inch plate cover while some do not have a plate cover at all.
Wall Mounted Faucets
Wall mounted sink faucets require a longer spout in order to provide easier reach. These faucets are installed on the walls and above the counter. Some bathrooms that have pre-installed sinks usually make use of this type of faucet.
Electronic Sink Faucets
Some new faucets even have electronic controls, such as the proximity electronic faucet. This type of faucet is usually used in commercial bathrooms. When a user places his or her hands under the spout, the faucet runs automatically. The water temperature can be controlled as well as its volume. Another type of electronic sink faucet is the touch pad controlled version. This version has a touch pad that can be used to control the temperature of the water and the flow volume as well. Although these types of faucets can be used for residential purposes, they are not recommended for home use because they are not very economical.
