6 Benefits to Installing Keyless Entry for a Garage Door Opener
One of the improvements that have been made with garages is the use of a keyless entry garage door opener. With this type of unit on your garage door, there are several great benefits to be enjoyed. Not only can a keypad opener raise the door, but it will also lock the door for you. If you are thinking about purchasing a keyless entry garage door opener, here are a few reasons why it would be a good purchase for you.
No Keys to Lose
The biggest benefit is probably the need not to have to carry around another key on your keyring. Not only does it reduce the number of keys that you carry around on your person, but it also helps reduce the chance of losing the keys and not being able to enter your home or garage. A keyless entry operates through the use of a pad where you press in a numeric code instead of using a key.
Multiple Access
There are times when you need someone to enter your home, but you will not be there. This could be a repairman, a babysitter, or a friend dropping by to pick up something they own or borrow. If you are going on vacation, you will also want someone to water your plants, feed the cat, or make sure the fish are still swimming. Having a keyless entry pad for your garage door opener will allow them to enter without worrying about using a key. Let them know the code, and they can come and go as they please.
Changing Your Code
Another great benefit, especially if you have given out your code to several people, is the ability to change it when you want to. It is recommended that you change the entry code on a regular schedule if someone has it that you do not want to let in more than once. Again, this could be a repairman or other type of service personnel.
Using A Guest Code
Besides changing the code for your keyless entry garage door opener, some models allow the use of a temporary guest code. This is a code that will only work for a specified period of time. After that time is over, the code will no longer work.
Lost Garage Door Opener
Not only is the keyless entry garage door opener convenient for helping others into your home, but it can also get you out of a jam. Besides losing keys or forgetting them, many people also misplace their garage door openers. Or, the battery could decide to stop working. The entry pad will still open the door for you to get in your home or park your car.
Wireless Control
Another benefit of this type of garage door opener is that it is not connected through wires. You can install it anywhere on your garage door that you would like without worrying about running wires to the garage door opener itself. It works by sending the information to the motor. When the right code has been entered, the door opens or closes.
