6 Best Uses for a Reciprocating Saw
A reciprocating saw, also called the Sawzall or a sabre saw, is basically an electric saw that is used for a variety of home projects. There are tons of household tasks that require different tools, but a reciprocating saw is an all-in-one tool that can take the place of several others. It uses a pull and push motion of the blade to cut, and it is often used in hard-to-reach places where no other type of saw can fit. You can cut through difficult areas like the corners and floors without a fuss. This is one of the best tools invented to make life—and DIY projects—easier to deal with. In this article, we will show you some of the best uses for a reciprocating saw.
Safety Note: As always, observe proper safety measures when using tools such as this cutting device.
1. Making an Indentation on Walls
When you are remodeling a unit and need to place wiring on the walls, you’ll need to make an indentation. A reciprocating saw is highly recommended when trying to do this, especially when the area includes odd angles.
2. Changing PVC Piping
PVC pipe is often located in places where regular saws can’t reach, so usually there is nothing more effective than a a reciprocating saw when modifying piping. PVC is easy to cut with this tool as well, so making any changes you need is a cinch.
3. Cutting Through Difficult Nails or Pins
Take advantage of the reciprocating saw when you come across nails or pins that prove difficult to remove. If you are working on a project where there is no other way to pull out a nail or pin because of its tough hold, you can use a reciprocating saw to cut the head as an alternative to pulling it out.
4. Cutting Tree Branches
If you need to take down branches in your yard, this is the perfect tool for the job because of its durability and cutting power. Why bother chopping it down with an axe when you have a fully equipped cutter that does not need much man power?
5. Fitting a Window
This handy tool is also what professionals use to cut down or fit a window since it can work easily in those tight and uncomfortable places.
6. Cutting Through Different Materials
When cutting with a reciprocating saw, anything goes, especially since its area of use is so flexible. You can cut almost any material, like wood, PVC, or even metals.
