6 Best Uses for Acrylic Latex Paint
Acrylic paint is not the best choice for all applications. However, there are some tasks that acrylic paint is perfect for. When evaluating whether acrylic paint is right for your project, consider the following information.
Wood
Using acrylic latex paint on wood surfaces can be beneficial whether it is inside or outside. This is because it is flexible and can handle any movements that occur, especially when it comes to extremes of temperature. For interior locations, such as wood trim, it is beneficial because it is durable and easy to clean. It is ideal for use in rooms such as the bathroom and kitchen where temperatures can quickly change and cause the wood to expand and contract.
Crafts
Acrylic latex paint is ideal for many arts and crafts because it is available in a great number of colors and dries quickly. Whether you are painting a canvas, a toy model, or an item of furniture, you will find that latex paint is the best choice. For larger artistic pursuits, such as murals, the paint can also be useful as it can be applied using an airbrushing method as well as a brush or roller. The process of creating designs on decorative items such as toy boxes and vases can be completed with the help of acrylic paints.
Masonry
External wall surfaces including concrete, stucco, and bricks can be painted with acrylic latex paint. It is resistant to peeling, cracking, and flaking due to its flexible nature, which helps to keep external surfaces looking good for a long period of time despite being exposed to the elements. The color with these paints is also long-lasting so do not quickly fade. The paint will adhere better of you initially clean the surface thoroughly.
Furniture
The range of materials that various items of furniture can be made from means that acrylic latex paint is an ideal choice for a number of different pieces. Whether the furniture is made from wrought iron or plastic and is used indoors or outdoors, using acrylic paint is the perfect way to change the color and protect the surface. This will enable you to wipe the surfaces when it is necessary to clean them.
Walls
The paint is available in a range of different finishes which means that it can be one of the options that you choose from when considering what to use to paint internal walls. In addition to it being suitable for the entire surface of the walls, it can also be used to add painted designs on top of existing paintwork or wallpaper.
Doors
Although the paint is not suitable for items that are to be completely immersed in water, it is capable of withstanding small amounts of water. This makes it a good option for the external surface of front doors and patio doors. The changes in temperature will not affect the paint and will stop water from affecting the wood.
