6 Best Wall Cladding Systems to Use
person installing exterior cladding in gray, red, and white bars
Wall cladding systems cover the exterior walls of a building to create a specific look. These wall coverings can also provide a protective layer to the exterior walls of a building. Wall cladding systems are available in various materials, including concrete, metal, wood, vinyl, and composite materials. These materials can be installed as panels or tiles. The covering does not adversely impact the structural integrity of the building. However, it is important to consider the weight of the cladding when deciding on a particular wall cladding system. The cladding does not support the weight of the roof.
1 - Vinyl
Vinyl wall cladding systems are available as side panels. The vinyl is made from polyvinyl chloride resin. This material is fairly inexpensive and easy to cut into the necessary lengths. The panels can also be easily replaced if necessary. Vinyl siding panels are available in a vast array of colors. These panels can vary in thickness and durability. Easy to maintain, vinyl requires no painting or finishing for protection. A seasonal power washing of the panels will keep them looking new.
2 - Metal
To install a metal wall cladding system, the metal must first be coated with a finish to prevent corrosion and rust. These coatings can be somewhat expensive. The types of metal used in wall cladding systems include aluminum and copper. An inner structure supports thin layers of these materials. The metal is fixed to the structure through a heat or welding process. Copper wall cladding systems provide a metallic look without negatively impacting the environment. Copper is not in short supply, and you can combine it with other materials.
3 - Concrete
Precast concrete wall cladding systems are available in panel form. These panels can be installed and later finished with concrete coatings. A variety of coating applications are available that can be used to create the look of stone, brick, and tile.
4 - Monolithic
This wall cladding system uses sheets of cement or plaster. Once the cement or plaster has been installed, the material is textured. This system is available in a variety of colors and textures. Monolithic systems provide poor insulation, and because of this, it is best suited to warmer climates where insulation is not necessarily a paramount factor in cladding the exterior walls.
5 - Wood
Reclaimed wood wall cladding is available if you are looking to restore a naturally aged wood exterior design. Lumber companies can cut recycled wood such as redwood into pieces for a wall cladding system. The wood pieces create a shingle or clapboard effect.
6 - Weatherboard
Weatherboard is much like a wood wall cladding system; however, it does not require finishing. This system is durable and holds up against most types of weather. The weatherboards can be installed horizontally or vertically, depending on the preference of the homeowner. It is also decomposable and is eco-friendly.
