6 Signs You Might Have Carpet Mold
Carpet mold can be a difficult problem to tackle. Mold can grow fast in damp places, and once it gains a foothold in your home, you have to put in a lot of work to eliminate it. Damp basements are ideal for mold growth. Likewise, rooms with insufficient ventilation also provide for a mold breeding ground. It may be difficult to detect carpet mold because it can thrive underneath the surface. Regular inspection is the only way to rule out carpet mold. Six of the signs that indicate the presence of carpet mold are found below.
1. Musty Odors
A musty odor in a carpet’s vicinity is a definite indication of the presence of mold, which will fester in a damp, enclosed environment. This musty odor might not be immediately apparent to you if you spend a lot of time in your home. However, take note if any visitors comment on a musty odor in your home because it could be a direct sign of mold growth on or under your carpets.
2. Higher Incidence of Allergies
Carpet mold can cause several health problems such as allergies, breathing troubles, asthma, and bronchitis. If you notice a higher incidence of such conditions in the members of your household, you must consider the possibility of carpet mold in your home. If the walls and floors in your home and basement look clean, be prepared for a thorough inspection of the carpet.
3. Damp Carpet
Any floor that remains damp or wet for more than a day may grow mold. If you notice that your carpet is damp, the cause may be a leak from the floor underneath. This scenario occurs mostly in basements. If you have had a water leak or similar accident, wherein the carpet was left wet for an extended period of time, you will probably find mold. A basement with leaking pipes is also a major cause of mold growth in nearby carpets. To prevent it from growing, dry your carpet quickly when there's an accident.
4. Green, White or Black Growth on the Carpet
In most cases, when the mold growth reaches an advanced stage, you can see discolored patches on your carpet. Most of the time, these patches are white, black, or various shades of green. The color is caused by the mold colony multiplying on your carpet.
5. Mold Growth Under the Carpet
A great way to keep ahead of mold is to regularly look for its presence on or under your carpet. Lift your carpet and thoroughly examine the floor under it. Look for any musty odors or discolored patches on the underside of the carpet, which are definite signs of mold growth.
6. Positive Results from a Mold Testing Kit
You can use a mold-testing kit to test the airflow across a carpet. The mold spores, if any, will land on the testing kit and multiply. These kits are one of the most reliable methods of confirming the presence of mold growth on your carpets.
