6 Tips for Applying a Second Coat of Deck Stain
Stain
Paintbrushes
Drop cloth
Eye protection
One of the ways to protect the investment you made in your outdoor living space is to use a quality deck stain. A stain will not only protect the wood from the elements but also add some color to the bare wood. There are several choices of stain color to coincide with your existing home siding. Of course, you can always use a regular wood-grain stain for that rustic look. When you apply stain to any outdoor structure, you will need to add a second coat. Here are some tips to help make applying that second coat easier.
Choose a Good Day for Staining
Since you will be applying two coats of stain on your deck, you should pay attention to the weather for the day you plan to do the project. Choose a day that is not too sunny, but will be warm enough. It’s also imperative that it won’t be raining when you stain.
Use the Same Stain
While this may seem like a no-brainer, there are many times when people will run out of stain and buy a different type. To maintain the same consistency of aesthetics, and protection, you should always use the same type of stain – both by style and manufacturer.
Use a Clean Brush
When applying an additional coat of deck stain, you should think about the end product. This is going to be the coat that stands out the most, so you want to have a smooth finish. You can reuse the brush a second time, but it will be hard and brittle if you don't clean your paintbrush immediately after the first coat. This leaves you with a brush that has uneven bristles. Use a second 4-inch brush to ensure a smooth application and finish.
Wait a Few Hours
Adding a second coat requires some precision in the time that elapses between the first and the second. Usually, a good time frame is anywhere between four and five hours. This, of course, will rely on the temperature outside. A good rule of thumb is to lightly touch the portion that has been stained. If it feels tacky to the touch (a little sticky and not wet) then you can apply the second coat.
Work Quickly
Once you work on one section of the deck, the other portions will be drying out. Maintain a constant motion until you are able to finish the entire deck or a different coloring will result.
Blot Excess Stain
As you move along with your second coat of stain, you should pay special attention to the spots where it is pooling instead of being smoothed out. Use a soft cloth to blot these pools of stain. By leaving this excess stain, you will have darker areas that can flake off because it is not part of the wood. As these are broken off, it will leave an area of wood that is unprotected from the weather conditions. Once it is blotted, use your brush to smooth it out and present an even coating.
