6 Tips for Choosing a Garbage Disposal
There’s no doubt that it’s very useful to have a garbage disposal in your kitchen. However, you need to be sure that you choose the right garbage disposal for your own specific requirements. When you look for a garbage disposal, you will find that there are many models available. Finding the right garbage disposal is quite easy once you know a little bit about them.
1. Regulations
The first thing to determine is whether local regulations allow you to actually have a garbage disposal. If you’re simply replacing an old model, this is unimportant. However, if you’re putting in a brand new unit where you haven’t had a garbage disposal before, remember to check beforehand. Not all areas allow for the installation of garbage disposals because of the increased strain they place on sewer lines.
2. Plumbing
Will your plumbing handle a garbage disposal? Not all existing plumbing will so take the time to check first. It’s also important to check your fixtures to discover what types of garbage disposal will be compatible with your current plumbing and sewer system.
Also, check to see if there’s an electrical outlet under the sink that can plug into the garbage disposal. Without it, you’ll need to wire it into an existing circuit and also wire in a switch.
3. Motor Size
A garbage disposal.
Many small garbage disposals come with a motor that’s just 1/3 horsepower. While that may be fine if you’re a single person in an apartment, you need something more powerful for a family home where the garbage disposal will be used more. You should ideally look for a unit that has a 1/2 horsepower motor. With a big house and plenty of people, you might even want a 1 horsepower motor on your garbage disposal.
This will be able to handle everything without straining so you’ll be far less likely to burn out the motor quickly.
4. Stainless Steel
Look for a garbage disposal with stainless steel blades. These are harder and sharper and will not only last longer, but will grind up the food more finely so you won’t have to deal with clogs in the pipes. Cheaper units will use far less stainless steel in their construction and are likely to wear out sooner. Bear this in mind as you check out units.
5. Dishwasher Attachment
If you have a dishwasher, you need a garbage disposal with a dishwasher attachment. This will attach via a tube and allow food from the dishwasher to be flushed into the garbage disposal where it can be ground up and rinsed away. The hook-up is very simple.
6. Extra Features
A sink with a garbage disposal.
There are several other minor features that you should consider. The biggest of these is the noise level of the garbage disposal. Make sure there’s a manual reset button on the unit and, ideally, a corrosion protection shield which will help the garbage disposal last longer. Sound baffles will lower the decibel level of the unit while anti-splash baffles will keep your sink cleaner.
