6 Tips for Mixing Turpentine
Turpentine is a flammable liquid that is used as a solvent, usually for paint and varnish. It thins paint and varnish to allow the painter to spread them evenly on a given surface area. When working with turpentine, there are precautionary measures that need to be considered. Below are tips for mixing turpentine.
Tip No 1 – Work in an Open Area
When mixing turpentine, it is recommended to work in an open area with good ventilation. Turpentine can cause health hazards when inhaled in excessive amounts. The substance easily evaporates in the air and gets inhaled easily when working directly with it. In many instances, mixing turpentine with other substances can be done in a place where there is good ventilation. In order to protect the body from the hazards of turpentine, work in an area where inhalation of the fumes of the substance is minimized.
Tip No 2 – Use Safety Masks, Goggles and Gloves
If the mixing of turpentine cannot be done in an open area or an area with proper ventilation, make certain to use a gas mask, safety goggles and gloves. The mask protects the wearer from inhaling the fumes of the substance, and the gloves protect the hands from coming into contact with it. Goggles offer protection from the irritating vapors of the substance as well. Take note that turpentine can also be absorbed through healthy skin. When it does get in contact with the skin, it is absorbed readily and may cause nausea and vomiting or skin irritation.
Tip No 3 – Use Artist Quality Turpentine for Oil Paintings
Turpentine is popularly used in oil paintings. When choosing turpentine to mix with oil-based paints, make sure to choose those with artist quality. This type of turpentine is very clear like water and contains no or very little impurities. Sometimes, supply stores may sell turpentine with impurities that may affect the quality of the oil paint. In order to get quality turpentine, make sure to check out product reviews to get an idea.
Tip No 4 – Use Metal or Glass Containers
Some substances that get mixed with turpentine may melt plastic containers. In order to ensure that the container does not get dissolved, use glass or metal containers. Use the containers only for the purpose of mixing turpentine with other substances. Do not use the containers for other purposes such as drinking or storing edible food.
Tip No 5 – Do not Mix near a Source of Flame
Understand that turpentine is a very flammable substance that may pose a fire hazard. When working with flammable substances, do not do so in places where they might light on fire.
Tip No 6 – Be Careful Not to Spill
Avoid spilling turpentine on certain plastic, rubber or surfaces coated with paint. The substance can dissolve some types of plastic and rubber and will certainly dissolve painted surfaces. Make sure to work carefully when mixing the substance to avoid any incidences of accidental spills.
