7 Inflatable Pool Kits on Amazon
With more people enjoying their time at home now than ever, an inflatable pool is a perfect investment to make the most out of the summer sunshine. They've come a long way from the kiddie-oriented limitations of yesteryear. These days, there’s no shortage of inflatable pool kits suitable for the whole family to enjoy.
Fast Set Above Ground Pool Set
This set is available in a range of sizes, which makes it a top contender. It boasts an easy setup process and an easy takedown, thanks to its built-in flow control drain. This pool includes a filter pump and cartridge to keep it clean easily. The 10 foot by 30-inch size is a great option to fit kids and adults in the pool all summer long. A few things to consider about this set are that it doesn’t come with an air pump, which is required for setup, and it needs level ground to fill and operate properly.
Intex 26167EH Easy Pool Set
This large inflatable pool is the perfect days upon days of summer fun. First of all, it’s large in size at 15 feet by 48 inches, fitting a whopping eight adults. The pool is highly durable, made of puncture-resistant three-ply material. The included filter and cartridge works to keep the pool sanitary. Perhaps best of all, this pool can be set up in a quick 15 minutes without the use of any tools. You can even use a garden hose to drain the water away when needed.
Summer Waves P10012362 Quick Set
At 12 feet by 36 inches, this inflatable pool kit is a fabulous choice to enhance summer in your own backyard. This pool features durable triple-layer polylaminate PVC with polyester inner mesh sidewalls, allowing you to use it without worrying about springing a leak. The kit also includes a filter for easy maintenance. The Summer Waves pool can be set up in mere minutes, allowing you to dive right into the fun. Finally, its faux gray wicker design is a more stylish option than many inflatable pools.
Intex 28405E PureSpa
If you’re looking to heat up your summer nights, an inflatable hot tub kit could be just the thing. This Intex PureSpa model measures 58 inches by 28 inches, fitting up to four adults. This hot tub features 120 bubble jets and a built-in heat pump for seamless and simple use. This model comes with an abundance of items, including a reliable filtration system with 2 filter cartridges, a floating pool chlorine dispenser, a ground cloth, an inflation hose, and comfortable headrests.
Sable Inflatable Pool
If you’re looking for something that is a little less high-tech and that takes up less room in your yard, the Sable inflatable pool could be the perfect option. This pool is great for adults, given its size, measuring 88 inches by 85 inches by 21 inches with a water capacity of 203 gallons. Sable boasts a high level of durability as this pool is built with high-quality PVC materials to make Sable’s inflatable pool 50 percent thicker than their competitor’s pools. Perhaps best of all, this pool is built for play and relaxing with a built-in lounge bench to allow you to soak up those summer rays.
Kid’s Intex Whale Spray Kiddie Swimming Pool
Looking for something for the kiddo in your life? This fun inflatable pool is the perfect choice to transform your backyard into something super fun for the summer. This whale-shaped kiddie pool comes with a sprinkler feature from the whale’s tail, which spouts water when easily attached to a garden hose. This pool measures 79 inches by 77 inches by 36 inches and has a 53-gallon water capacity. It has a handy drain plug, and the kit also includes a repair patch to keep the pool in great shape for summers to come.
Action Air Inflatable Activity Center
To make your backyard truly the coolest in the neighborhood, Action Air’s activity center is just the thing. With a slide, bounce house, splash pool, and built-in water gun, it’s sure to be a hit with the kids in your life. While this inflatable kit does come with a higher price point, the ease of setup and high-quality design makes up for that fact. This kit includes the inflatable bouncer, air blower, water tube, repair patches, lawn stakes, blower stakes, and a portable carrying bag.
Make the most out of the warm summer months by turning your backyard into a complete oasis, thanks to these handy inflatable options.
