7 Outdoor Electrical Wiring Safety Tips
When it comes to faulty outdoor electrical wiring, you can do the fixing on your own, especially if the problem is quite simple. However, before you embark on any electrical project, may it be indoor or outdoor, you need to first ensure your safety. Below are seven helpful tips that you need to remember when working on outdoor electrical problems.
1. Check your Tools
Many outdoor electrical wiring accidents are caused by using the wrong equipment or tools that are damaged or malfunctioning. To make your electrical wiring job safe, you have to ensure that all your tools are well-maintained and functioning properly. Moreover, your gadgets should have safety features, such as insulated grips and ground fault circuit interrupters. If you are going to use extension cords, choose ones that have heavy gauge and can be used outdoor.
2. Invest in Safety Gadgets
Homeowners who are interested in doing minor repairs of home electrical outlets should invest in safety devices. These things are not that expensive compared to hospitalization bills and other expenses related to electrical accidents. Some of the tools that should come in handy when working with electrical wiring outdoors include leather gloves, hardhat lined with flame resistant material, and safety goggles with shields.
3. Wear Appropriate Clothes
Appropriate clothing is very important when working with electric plugs, wiring and cables outdoors. Protect your body with a flame-resistant long sleeved shirt. Do not wear synthetic materials, as they are highly flammable and can melt onto your skin if exposed to fires and electric sparks. Leather work boots should also be used for safety.
4. Use Extreme Caution when Using Ladders
When working with outdoor electrical wiring, using a metal ladder is a big no. You should instead use ladders that are made of wood or fiberglass material. Make sure that you or your ladder does not come into contact with any live wire. Sometimes, even wooden ladders can conduct electricity when they touch a live wire.
5. Never Work with a Live Wire
One of the most important rules when it comes to working with electrical wires is to ensure that they are not live. A wire becomes live when electricity runs through it. Be sure to turn respective circuit breakers off and test all wires, circuits or conductors before working on them. Invest in affordable hand held voltage testers before embarking on tasks that deal with electrical wires.
6. Check Local Outdoor Wiring Codes
Before you do any electrical outdoor wiring project, you should know your local safety codes and regulations. You need to make sure that the plugs, wires, electrical outlets, lighting fixtures, or appliances that you are going to use outdoors are safe and approved by authorities. Using substandard materials that are not fit for outdoor use can cause fire or electricity-related accidents.
7. Know Proper Wiring Techniques
Only a person who has a clear understanding of outdoor electrical wiring should attempt to fix and install any wirework. Wires should also be properly connected and kept so as to prevent shorting and other similar problems. If you think that the wiring problem is too complicated for your experience and training, you are better off calling a professional to do the job.
