7 Safe and Organic Ways to Get Rid of Spider Mites
a Spider
  • 2 hours
  • 50
Water
Hose
Lemon
Neem oil
Predator insects
Insecticidal soap
Spider mites are one of the common nuisance plant pests. They are capable of rapid reproduction which can cause a nightmare for any gardener. Reproductive capacity is encouraged by warm, dry temperatures. These pests attack flowers as well as vegetables. It is a good idea to always be vigilant for signs of infestation. Most infestations occur in the summer due to warmer temperatures. The following are some safe and organic ways to eliminate spider mites.
Plain Water
It is a simple yet effective means of eliminating the spider mite. You will need a garden hose with a high pressure nozzle. Identify the garden plants that show signs of infestation. Set the nozzle onto the affected areas and spray hard. The water will wash off virtually all the mites. Pay attention to the undersides of leaves for greater mite concentrations. It is best to do this in the morning so that the plant has adequate time to dry out.
Lemon Water Spray
Obtain some lemon juice. It is preferable to squeeze fresh lemon juice. Mix with water in a 2:3 ratio. Fill a spray bottle and spray the entire affected plants with the solution.
Mixture of Alcohol and Water
Make a mixture of alcohol and water in a 1:1 ratio. Put into a spray bottle for easier application. Identify the plants that show infestation. Spray the affected plants entirely. Be sure to spray underneath the leaves where the mites tend to gather.
Insecticidal Soap Spray
Neem oil repulses spider mites. Obtain neem oil soap. Make a spray using neem oil soap and water. Put in a spray bottle and spray infested plants. Cover the under sides of leaves as mites frequently occur here.
Predator Ants
Obtain some predator ants from a garden store. These feed on the mites and will help to eliminate quickly and safely. For indoor plants in containers, it is best to take them outside. Place some sugar around the base of the plant. It will help retain the ants around the plant. Introduce the ants to the sugar to feed on it. Once they are done with the sugar, the ants will soon trace and feed on the mites.
Isolate Affected Plants
Identify affected plants in containers. Isolate them to help check the spread of the mites. They migrate rapidly from plant to plant. Keep the infested plants in clusters. This will encourage higher moisture levels, which is a deterrent to mites.
Provide Shade
Spider mites are not fond of moisture, damp, wet or shady conditions. If affected plants are in containers, shift them to a shady area. This is especially recommended in the afternoon when temperatures are warmer. For indoor plants, you may want to draw the shades when it gets hot. You could also use a humidifier next to the affected plants. For plants that are in the garden, you may want to erect a temporary shade during the afternoon. It will discourage the presence of the mites.
If you need to get rid of spider mites in your home, follow our guide on how to get rid of spider mites in your home.
