7 Steps to Replacing Your Motorcycle Mirrors
a red motorcycle
  • 2-4 hours
  • 30-125
General tools
New handlebars
Glue
Sharp knife
New hand grips
General tools
New handlebars
Glue
Sharp knife
New hand grips
Pimping your bike does not have to be complicated or expensive at all; all you need is to replace your motorcycle mirrors to achieve the statement that you want with your bike.
Step 1 – Find the Comfortable Spot
Before you go ahead and take the handlebars off your motorcycle, experiment first as to which part of the handlebars feel most comfortable to you. To do this, hold your existing handlebars and move your grip from the higher, lower or wider parts of the bar. If you feel that the current handlebars that you have is comfortable enough for you, check if the height of the handlebars are to your liking. If they aren’t you can always raise or lower them using risers. Also keep in mind the measurements of your existing handlebars especially when selecting the measurements of your new handlebars. Be careful with selecting wide bars because such bars are notorious for making turns difficult.
Step 2 – Remove the Parts
The very first part that you should remove is the brake lever which is sometimes called as the master cylinder unit. Also remove the switch housing and the throttle control. You will be able to locate these parts using your motorcycle’s manual. Be very particular about clamps and other wiring harness that you will be detaching. Once you have removed the throttle control, you will need to remove the brass ferrules. The ferrules are found at the ends of the cables. Proceed to removing the hand grip and clutch lever assembly. Also remove any accessories that you may find that are attached to the bar. Put all the parts in rags to prevent losing any of them.
Step 3 – Remove the Left Hand Grip
Unlike the right hand grip, the left hand grip is usually immovable hence making it difficult to remove. Using a sharp knife cut through the hand grip.
Step 4 – Remove the Riser Cover and Riser Clamps
Not all motorcycles have riser covers and riser clamps but if yours do, make sure to remove them first before removing the handlebars. You can install a new set of risers if you want.
Step 5 – Install New Handlebars
Replace a new set of handlebars in exchange for the old ones that you have just removed. Make sure that the handlebars are positioned at the very center of the risers. Once you have done so, place the riser clamps and riser cover. After installing the new handlebars, try turning the bars left and right to make sure that there is enough clearance.
Step 6 – Reinstall the Removed Parts
Replace the switch housing that you have removed in the left handlebar. Apply a film of glue on the bar and attach the new hand grip. Also reinstall all the other accessories that you have removed in the first few steps.
Also reinstall the brake lever and master cylinder on your bike’s right handlebar. Before attaching the switch housing, make sure the reattach the brass ferrules on the cables. Secure the throttle control on the bar and secure the switch housing tightly.
Step 7 – Test the Switches and Wires
Try all the reinstalled switches and wires and make sure that they are working properly. Recondition the throttle and idle cables according to your manual. Make sure that your clutch cables are on snugly and that there are no defects on the wires.
