7 Tips for Attaching Chain Harrows to a Tractor
Chain harrows are an invaluable attachment for dragging gardens and making sure that lawns are level. Chain harrows are much like a large rake, but are attached to the back of a tractor for coverage of much larger areas. Chain harrows come in several different configurations for different applications like pastures, gardens, lawns, spreading manure, cultivating fields, and even smoothing ball fields. The key to proper use of the chain harrows is how they are attached to a tractor.
1. Multi Use Attachment
Many of the attachments that can be bought for yard work have a very specific job. The chain harrow is different in that it can perform many different tasks by simply being pulled behind a tractor. For large scale operations, there are fairly large chain harrows that can take care of wide areas at a time. Anyone who has a garden, small pasture, horse corral, or lawn will want to make use of the chain harrow for a much better presentation of their landscape and better planting.
2. Use 3-Point Hitch
A 3-point hitch is a special type of connection on a tractor that is often times attached to some hydraulics for lifting, angling, and engaging the attachment. Some 3-point hitches are simple metal brackets where there are three points of securing the attachment for better control. When attaching a chain harrow to a tractor, use a 3-point hitch for much better control over the apparatus.
3. Use in Conjunction With Boom
One of the problems that many people have with a chain harrow is transporting it across roads or thick brush. When attaching to a tractor, the chain harrow should be used in conjunction with a boom. This way the harrow can be employed while going forward, and then lifted when going in reverse or across roads.
4. Make Sure Steel Crossbar is in Good Shape
The steel crossbar on the chain harrow is what keeps the harrow straight when behind a tractor. Without the crossbar the chain is flimsy and will not go around corners correctly. Check this steel bar before attaching to make sure there are no cracks and it is not bent.
5. Keep Chain Harrow Straight Before Moving
Another problem many people run into when using chain harrows is that the chain is not completely rolled out before they start to move the tractor. The chain must be fully deployed for the harrow to work in a correct manner. If there is any amount that is still rolled up on itself, it will leave large gouges in the landscape. Stretch out the chain fully before moving forward with the tractor.
6. Pull Chain Harrows at Five Degree Angle
To get the best effect from the chain harrows you should make sure the attachment chains are adjusted enough so that there is a five degree down angle on the actual tines in the harrow.
7. Make Sure Tractor Can Pull Chain Harrows
Large tractors will not have a problem with the chain harrow being pulled behind it. However, some small garden tractors, and lawn tractors, are not built to handle the strain of pulling a chain harrow. Check the hp rating of the tractor to ensure that it is large enough for a chain harrow.
