8 Common USB VGA Adapter Problems
2 hours
Intermediate
- 25
When you’re trying to connect a USB VGA adapter for the first time, you may run into some significant problems. Here are some of the most commonly reported problems with installing USB VGA adapters to hardware setups.
General Driver Issues
Typically, each kind of device that is attached to a computer needs its own driver. The driver is a software piece that helps the computer to recognize the accessories and their intended uses. Without the right drivers for a USB VGA connection, companies cannot ensure that their products will work successfully with a home or commercial hardware setup.
General Video Card Issues
Output to a VGA or video graphics array screen requires a certain kind of video card capacity on the computer. Computers without video cards will not be able to utilize a USB VGA connection successfully.
Primary Display Issues
Some monitors and screens or other hardware have restrictions that are built-in. These may include a software component that blocks the USB VGA output from becoming the primary display. This can cause frustrations if a user has to find the right display settings to make use of this kind of adapter.
DVD Playback Issues
Some kinds of DVD player technology don’t work with just any kind of video connectivity. This can be another issue facing consumers who are installing a USB VGA adapter that is meant to route a VGA signal to a VGA monitor using USB connectivity.
Windows Media Player Issues
Along with being sure that you have the right codecs for video files in Windows media player, there also may be some Windows media player settings that are not compatible with a certain kind of video output. If you encounter problems with Windows media player, try different video players to see if the problem can be isolated.
Low Refresh Rate Settings
The refresh rate for updating a video image can be set too low to accommodate a VGA output. If you encounter visual problems with an existing image, they may be due to a low refresh rate. Look for specific information in your computer manual for repairing any issues with low refresh rate settings.
Screen Resolution Issues
It’s important that video screens and monitors have enough screen resolution to handle the VGA signals being outputted to them. Check your screen resolution capacity for your monitor when you are adding it to a hardware system using a USB VGA connector or adapter.
Connectivity Problems
Some troubleshooting for USB VGA adapters just involves making sure that everything is plugged-in correctly. If problems do occur, do a quick double-check to ensure that they are not related to incorrect plugins. You’ll also want to look at your home or commercial wireless network if this applies to your USB to VGA graphic or video output.
The above issues can happen when buyers install USB VGA adapters. Hooking up old VGA technology using Universal Serial Bus connectivity can be frustrating if parts or devices are not compatible. This can be one of the trickier jobs for those looking to upgrade display capacity for hardware. It helps to buy from companies that provide direct tech support, in case problems do arise.
