Lumber & Siding
Featured Articles
Siding can protect your home and give it a new look.
When durability and affordability are project priorities, consider plywood as the material of choice.
What do you do when tiny black spots start appearing on your siding?
Follow these steps for a long-lasting paint job.
All the different siding options can be overwhelming.
The pros, the cons, and the installation process of natural wood siding.
Here are several finishing options for tongue and groove pine siding to give that something extra to your next do it yourself siding project.
Veneers offers a wood look without the weight of solid wood.
Focus on preparation for a job well done.
Match the right type of wood to the right project.
Use flashing to protect your window investment.
Maple is a great option for many household projects.
To install a window, you must first create an opening.
Pine trees contain surprising variety.
Corrugated steel siding is a popular choice among homeowners as it is fire-resistant, cost-effective, and repels damage from weather.
Fiberboard makes use of wood fibers for a cost-effective material used in many household applications. The article that follows will share with you the best uses of fiberboard
Wood siding can be installed vertically or horizontally.
Painting aluminum siding requires a different technique.
This wood weathers very well and is very commonly used for outdoor projects.
Furniture, flooring, and even cabinets are made with particle board, but it requires gentle care in order to last.
What you need to know before deciding whether to use redwood and douglas fir lumber.
Install wall cladding, aka siding, to protect your home.
