How to Install a Stained Glass Light Fixture
2-3 hours
Beginner
- 200-400
A stained glass light fixture is a great addition to your bathroom because it will illuminate in a way that adds a colorful, old style feel.
Turn of Power
Turn off power to the room where you will be working at the circuit breaker. If the receptacle you will be tying into is in a different room, then cut power to this room as well.
Select the Locations
Find a location in the ceiling and wall where you want your stained glass light fixture to be installed. Try to place the light switch directly above a receptacle in order to reduce the work necessary to supply power. Use a stud finder to verify that the locations where you will be installing your light and switch do not contain a stud. If both locations contain a stud, then offset these locations accordingly.
Make the Cuts
Place the cut-in boxes in the locations where you will be installing the light and the switch. Use your pencil to trace around the boxes. Use your drywall saw to cut the drywall in both of these locations.
Drill the Hole
In the attic, use your drill and a paddle bit to drill a hole in the top stud of the wall within the same stud bay as you are installing the switch. If you do not have a receptacle in the same stud bay, then you also need to drill a hole in the stud bay where the nearest receptacle is located.
Run the Wire
Run your 12x2-inch electrical wire from the location where the light will be installed to the hole which you have cut for the switch. Then run a wire from the hole for the switch to the nearest receptacle.
Install the Cut-In Boxes
Tighten the screws on each of the cut-in boxes until the flaps on either side swing out and tighten down to the drywall. When it is fully tightened, the boxes should be securely mounted to the drywall.
Wire the Switch
Connect the black wire to the copper screw, the white wire to the silver screw, and the solid copper wire to the green ground screw. Connect this wire at the switch to the constant hot side of the switch using the black as hot, white as neutral, and the copper as ground. Then connect the wire which runs from the switch to the light fixture.
Install the Bracket
Install the bracket to the electrical cut-in box. Use the screws which were supplied with the ceiling mount to secure it.
Wire the Stained Glass Light Fixture and Install the Light
Connect the wires supplied for the light by twisting the light's wires around the wires which run to the light switch. Use your side cutting pliers to securely twist these wires together. Wire nut each of the wires together. Slide the light through the ceiling mounting bracket, followed by the washer, and finally the nut. Tighten the nut until it is secure.
Install the Stained Glass Cover
Slide the stained glass cover over the light and tighten the bottom nut. Tighten it until the glass cover is fully secure.
Testing
Turn the power back on and test your new light.
