Adjust a Lazy Susan Cabinet in 5 Steps
cabinet being repaired with a drill
  • 1 hours
  • 0-30
Flashlight
Screwdriver
Flashlight
Screwdriver
If you find that your lazy susan cabinet needs adjusting because the shelf isn’t high enough or low enough, it is very easy to fix.
Step 1 – Empty the Cupboard
Take all the goods out of the cupboard
Step 2 – Locate the Support Bracket
Look under the Lazy Susan shelf and you will see that it is supported by a bracket.
Step 3 – Bracket Screw
Lift the Lazy Susan shelf and you will then see that the bracket is held in place by a single screw.
Step 4 – Adjust the Bracket
Holding the shelf up, loosen the screw until you can slide the bracket into the required position. This can be a very frustrating exercise and you may need to lay a flashlight in the cupboard so you can see what you are doing.
Step 5 – Fix
Tighten the screw so that the bracket is held in the new position.
That is all there is to it.
You can now replace the things into the cupboard (if you weren’t aware you had them check the dates in case they have been stored too long) and check that the shelf turns freely and that nothing causes an obstruction.
