Advantages and Disadvantages to Using Granite Paint
If you’re considering using granite paint in your home decorating scheme, you need to know a little bit about the product and its limitations before you set to work. Granite paint is designed to mimic the look of natural granite. However, it isn’t actually as durable as granite, so bear this in mind when using it.
Don’t Use Granite Paint for High Traffic Areas
Granite paint isn’t an excellent choice for high traffic areas in the home, such as stairways or hallways. It’s a product that is prone to crumble over time, so it's best to avoid using it in places where a constant stream of hands is likely to be passed over it.
Porous Materials and Granite Paint
Although it might seem logical in theory to paint over cement with granite paint to achieve a stone-like effect, this rarely works in practice. The textured nature of the paint can clog in the pores and cracks of the concrete, and you won’t achieve a desirable finish. You would also need to use a lot of product as concrete is notorious for sucking in paint. If you want to avoid a blotchy effect, don’t paint concrete with granite paint.
Granite Paint and Moisture
Painting with granite paint in a bathroom, shower room, or kitchen should be avoided. The paint isn’t particularly water-resistant, and while the effects might look impressive, to begin with, it won’t be too long before the walls become marked, and the paint starts to absorb water and flake off. In rooms where a wipe-clean surface is required, granite paint is not a good choice.
Granite Paint and Smooth Dry Surfaces
Granite paint is ideal for painting living room and bedroom walls. Remember, this sort of paint is designed for durability and cleanability.
Granite Paint Is Permanent
Granite paint isn’t easy to remove once applied, and as it is textured, it’s not easy to paint over. Be sure that you are happy to paint your walls with this product before going ahead and opening the can. If you make a mistake and need to remove granite paint from a wall, it is sometimes necessary to use a sander to remove it. This is quite a task, so we cannot stress enough that you really need to be certain that you can live with it.
Easy to Use
Although granite paint is somewhat limited, it is ideal for simulating a stony look in the right circumstances. It’s easy to use and can be applied in much the same way as regular wall emulsion. Drying times are standard. It's favored by those who like a contemporary feel or a traditional, natural look.
Use paintbrushes or paint rollers to apply the paint. Because the final results of granite paint are natural, it makes a good cover for less than perfect walls. A matt finish disguises any imperfections in working surfaces most effectively.
